I haven’t found a page that explains what I see on the network map. I guess
The colour of the lines (green → yellow → red → grey) is the quality of the connection.
What do the numbers on the lines mean? Lower numbers seem to indicate poorer connectivity, but
– do these numbers have units?
– What is the signficance of two numbers: x/y ?
Finally, in the diagram below, you can see that some devices are not connected to the network. Only one of those devices is shown as offline (which is correct as the device is powered off). However, what does that mean for the other devices that are not connected? Are they not connected at the moment because they are not sending data, but will connect later? Is is the signal strength so poor it doesn’t even get a red line?
Also, what surprises me is that some of the devices that don’t have lines are really close to the conbee II (2m, no walls), so I would have expected them to connect. The conbee II has connected to devices that are much further away (and separated by walls etc).
All devices (apart from the one that is genuinely offine) are (or at least appear to be) working.
Does anyone know what the dashed lines in the visualization is? I have some dashed lines with arrows at the end all pointing to a controller. ?? And, they’re all green.
Update: they are all of the colors. Green, yellow, red, and gray.
Enable physics just lets the nodes bounce around if you manually move the node around on the map. Like a kind of auto correction. Try it.
Disabling it doesn’t let any other nodes move if you move one too close to another.
If it helps this is from the integration before it was embedded into HA:
The Zigbee coordinator will be represented by a rectangle at the top. Any device that serves as Zigbee router (usually all devices running on Mains electricity / grid power) will represented as ovals, and Zigbee end-device (usually battery powered sensors) will be represented by as circles.
The lines between those representions show all the possible paths through Zigbee mesh. Any path with a LQI over 192 is shown as green, LQI 129-192 is shown as yellow, and anything 128 and lower is shown as red.
