Hi All,
I’m running the laters version of hass.io on a RPI4
Is there a possibility to join/unjoin Yamaha musiccast speakers?
I have a receiver RX-V483 and a speaker WX-030.
This is the configuration in yaml.
# Musiccast Keuken
platform: yamaha_musiccast
host: !secret mc_keuken
port: 5004
# Musiccast Woonkamer
host: !secret mc_woonkamer
port: 5005
I have created a mini media player card
entity: media_player.woonkamer_main
type: 'custom:mini-media-player'
artwork: cover
speaker_group:
show_group_count: true
entities:
- entity_id: media_player.keuken_main
Every time I try to join speakers I get the error message
Failed to call service yamaha_musiccast/join. Service not found.
Its not supported, I wish it was, this would be so good.
ppanagiotis
(Panagiotis Panagiotopoulos)
June 27, 2020, 2:02am
3
@ppanagiotis thanks for the pointer, but I encountered the same issue as @Sander_Wolschrijn
I have tried platform as both yamaha_musiccast and musiccast_yamaha
Card as shown in Lovelace UI:
Error message when attempting to “group”
I installed Mini Media Player v1.11.0 from HACS
@Sander_Wolschrijn did you mange to get groups working for Yamaha Musiccast devices?
thanks!
[Edit 3 hours later]
It works!!!
I was confused between the instructions for:
HACS Frontend: Mini Media Player and
HACS Integration: Musiccast Yamaha
I uninstalled/reinstalled HACS Integration: Musiccast Yamaha and changed the config.yaml media_player platform entiries to musiccast_yamaha
Thanks for your post. I gave up on this and moved on to other interesting stuff to do with home assistant. But your reply awoke me again . Used your method and now everything is working fine.
@YetAnotherDave , hello.
Did you manage that mini player is working and you have group of musiccast devices? could you please share code with mi?
thank you for you help
Filip
@Filip_Kotian this is the change that made it work for me:
All with fixed IP address and a “unique” port.
Along with this Entities Card Configuration :
icon: 'mdi:audio-video'
type: entities
entities:
- type: 'custom:mini-media-player'
group: true
entity: media_player.tv_room_rx_479_main
artwork: cover
speaker_group:
platform: musiccast_yamaha
expanded: false
entities:
- entity_id: media_player.tv_room_rx_479_main
- entity_id: media_player.office_main
- entity_id: media_player.wx10_livingroom_main
- entity_id: media_player.wx21_diningroom_main
group: true
entity: media_player.office_main
group: true
entity: media_player.wx10_livingroom_main
group: true
entity: media_player.wx21_diningroom_main
vicfalls
(Vicfalls)
May 14, 2021, 4:29pm
8
@YetAnotherDave , have you done anything about this information below?
from the github pymusiccast instruction .
It is confusing and I got stuck… I followed your method, but still get the same error message
Yes, I too was confused. I believe the problem is that you are using yamaha_musiccast
What you need is musiccast _yamaha
See my earlier post, partially quoted here:
vicfalls
(Vicfalls)
May 15, 2021, 12:33pm
10
YetAnotherDave:
musiccast _yamaha
Thanks, that’s it!!!
You have to have it correct in the configuration.yaml file → musiccast_yamaha
Works perfect now.
Sorry for refreshing the topic, but I think I don’t understand what should be the final configuration. Is that the one posted by @YetAnotherDave ?
This post is how I have it configured. It still works for me
core-2021.5.5
supervisor-2021.06.8
Home Assistant OS 5.13
HACS 1.12.4
Musiccast Yamaha v0.5
Mini Media Player v1.12.1
I also have some problems getting my Musiccast system up and running with Homeassistant. I browsed the examples here and on GitHub - ppanagiotis/pymusiccast: Group MusicCast Speakers with Home Assistant to do the installation. I made a card in Lovelace like this:
type: entities
entities:
- type: custom:mini-media-player
group: true
entity: media_player.esszimmer
toggle_power: false
artwork: cover
hide:
icon: true
power_state: false
speaker_group:
expanded: false
entities:
- entity_id: media_player.esszimmer_main
- entity_id: media_player.kuche_main
- entity_id: media_player.schlafzimmer_main
artwork: cover
group: true
hide:
icon: true
controls: true
progress: true
source: true
info: true
power_state: false
entity: media_player.kuche
toggle_power: false
artwork: cover
group: true
hide:
icon: true
controls: true
progress: true
source: true
info: true
power_state: false
entity: media_player.schlafzimmer
toggle_power: false
This is what the card looks like:
I also add my devicecs in the configuration.yaml file. My problem is this: I cannot control or group my devices. When I click the slider, nothing happens. The slider does not move. I can only turn the devices on / off and adjust the volume.
What am I doing wrong?
Hi Guys
Has the Musiccast Group Issue been resolved as i am still recieving the Error that service not found
onkelbeh
(Onkelbeh)
September 5, 2021, 3:25pm
15
Also cannot get it working with the ‘official’ aiomusiccast-0.9.1 (https://github.com/ppanagiotis/pymusiccast says it’s deprecated), all documentation I find is very outdated.
I’m on 2021.9.3, the integrated MusicCast (at least their docu says) should provide a join routine.
But it tells there is no service musiccast/join.
Here’s how it looks with platform set to mediaplayer:
This is my custom card:
type: entities
entities:
group: true
entity: media_player.rxv_werkstatt
name: RXV Werkstatt
toggle_power: false
artwork: cover
hide:
icon: true
power_state: false
source: false
speaker_group:
platform: media_player
expanded: false
entities:
- entity_id: media_player.rxv_wohnen
- entity_id: media_player.rxv_kueche
group: true
entity: media_player.rxv_wohnen
hide:
icon: true
controls: true
progress: true
source: true
info: true
power_state: false
group: true
entity: media_player.rxv_kueche
hide:
icon: true
controls: true
progress: true
source: true
info: true
power_state: false
if I change the speaker_group platform to musiccast, it looks like this:
onkelbeh
(Onkelbeh)
September 5, 2021, 4:47pm
16
Played a bit, found a workaround:
service: media_player.join
entity_id:
- media_player.rxv_wohnen
group_members: media_player.rxv_wohnen
added a button card for it.
This is my screenshot of Musicast devices.
I will try the button setup but that would require multiple buttons if a eventually add all musiccast devices in each room
My Card View
Do you know if there is currently an Open Issue for this intergration
onkelbeh
(Onkelbeh)
September 6, 2021, 5:03pm
19
I think not, I opened one yesterday: https://github.com/vigonotion/aiomusiccast/issues/20 .
You do use the (deprecated) musiccast_yamaha
platform,
but I want to get it working with the ‘official’ platform, which is now musiccast
Take a look at my previous post , I think it is an issue of mini-media-player
, not of the musiccast platform.
Just tried to add the master like you did in your screenshot,
the error stays the same:
onkelbeh
(Onkelbeh)
September 6, 2021, 5:34pm
20
Yep, it’s a (solved) issue with mini-media-player, which does not honor the new join method in media_player platform (https://github.com/kalkih/mini-media-player/issues/528 ). There is no bundled release yet.
