I am trying to figure out how to load a JSON file/call into something i can parse through in some type of card.
I want to base this on this: Nearby EV Rapid Chargers
This returns a static 3 stations.
I want to change this and return the closest X chargers in a given raduis.
I have changed the API call to OpenChargers to return all chargers in a given radius. I now need to make the card dynamically display the results from the JSON
First I don’t understand how to make HA load a rest.yaml file. So far I have just put the “rest.yaml” into configuration.yaml
This gets me only so far.
The JSON I am trying to parse in: http://mrstars.com/chargers.json
(this is a static file which represents a call to openchargers api)
This returns the X closest chargers based on a radius so the size of the JSON elements are dynamic
I want to load the results into something I can parse through in a card of some type
I want to be able to dynamically go through the chargers instead of using a static 3 results…
I want to do something like:
for each (EvChargers) in JSON
output Name
output Slots avalible
output Distance
How can I do this??
