Brain not working today and I know this should be relatively straight forward but how do I monitor my Synology NAS Docker Eclipse Mosquitto status? Watchtower recently upgrade the container and the broker went down but I didn’t know. I need to create a notification in these scenarios.
The MQTT config reports hass/status (offline/online) but that is for HA itself. I need to know if the broker dies while HA is up.
Using something like that, if the broker does go down, then you could have HA notify you. However, I would go with something like Portainer, Prometheus, or even the Docker API. My personal choice is Prometheus as it’s robust enough to monitor dozens of containers in a pretty small footprint.
Thanks for the reply. One would assume that any topic updates on $SYS would actually die if the broker goes offline so I’d have to set up a sensor around that? I’ve tried monitoring $SYS/broker/clients/# and get nothing so I’m assuming there is some trick to monitoring broker system messages?
It might be easier just to group a bunch of my MQTT clients together and create a binary sensor that triggers if they all go offline indicating a network or broker issue that requires further investigation?
I know that article well as we run multiple MQTT clusters for work. While the article is correct, those use cases are mostly for production/enterprise environments. To be fair, outside of the most hardcore of home automation enthusiasts, no one is running multi-tenant, MQTT clusters in their home environment; Most often they’re running a single instance, most likely in a docker container. I might be one of the outliers as I run a small, load-balanced MQTT cluster behind a haproxy instance hosted on my opnSense box.
For the home user looking to track if their broker is online and responding, and/or wanting to see what clients are doing, $SYS topics are fine for that. It’s when you start getting into multi-tenant, enterprise level clusters that the $SYS topics fail as they aren’t scalable across the cluster.
Thanks. I’ve tried subscribing to $SYS/broker/clients/# but the subscribe button is greyed out in MQTT.fx when $SYS is added at the front as I’m assuming it doesn’t recognize/support ‘$’ as a valid topic name.
My approach has been to create groups with six MQTT entities that are spread around the house; two from each of the three access points. I’ve got four groups in total; one for each of my three AP’s and a ‘master’ group that contains the other three sub groups.
I have custom SSID overrides on my AP’s so devices don’t roam to weaker AP’s so it’s easy to assign two MQTT entities that are connected to a specific AP. In that way, I can report if the problem appears to be AP related (after a rogue UniFi update) or whether multiple devices connected to multiple AP’ are all offline indicating a possible broker offline issue.
I’ve just created half a dozen binary_sensors like the examples below as so far it seems to be working well.
