How do I pair a Meross garage door opener with a Tuya Switch?
Hello all,
I have a Meross garage door opener as HACS Meross LAN integration, which is already working well:
Then there is a Tuya Switch, which is also already functionally integrated as HACS Local Tuya integration:
Sorry, but i am not able to add more than 1 grafics here in my post! :frowning:
I have already created a simple automation that triggers the garage door OPEN when the switch is turned ON and vice versa:
This works quite well already.
BUT…
It should also work the other way around.
That is, if one triggers the garage door at another place on OPEN, then also the Schlater should have the condition ON, which lets this then also leiuchten and one knows that the garage is open.
Here already once a question: If I set up this as automation, do I have then a loop with the other automation?
The ON state of the switch should also jump back to this, as long as the garage door is OPEN and only stand on OFF, when the garage door also experiences the state CLOSED.
Can this be done somehow?
I don’t quite get it. I am still new in HASS.
Thanks for your tips :slightly_smiling_face: .
ragards!
Do you need more informations? Which?
Or should I complain it different?
