Hello. I have a Raspberry Pi 3B. It is running on Raspbian Buster. This is my Pi Hole setup but I wanted to install Home Assistant. I found these instructions and followed them.
To access the raspberry pi, I am using the terminal app on my iMac.
The problem is that Home Assistant keeps shutting down. I’m not sure what events shut it down but when I close the terminal app, Home Assistant shuts down. Even if I keep the terminal app open but my mac goes to sleep, Home Assistant shuts down.
How do I keep Home Assistant from shutting down? Thanks.
You run Home Assistant Core in a venv, and start it from a SSH session. Any program (not just HA) started in a SSH session (except services) will shutdown when you close your SSH session. That is expected behavior.
The instructions to start HA as a service are linked on the page you linked above, but I repeat them here again :
