palengh
(Pål Engh)
November 29, 2020, 3:18pm
1
I am setting up a small OLED screen, and I want to show current time, and some weather conditions like current weather, wind force and temperature. I get all to show correctly, except for the string from sensor.yr_symbol_current
I was hoping printf with the parameter %s would work, but unfortunately not.
How can I print the state (as text))
My first sensor below, id: current
is based on sensor.yr_symbol_current
where {{ states.sensor.yr_symbol_current.state }}
returns Regn (rain) in the template builder.
What am I missing here?
- platform: homeassistant
entity_id: sensor.yr_symbol_current
internal: true
entity_id: sensor.yrcurrent_wind_speed
internal: true
entity_id: sensor.pir_ute_paviljong_temperature
internal: true
display:
- platform: ssd1306_i2c
model: "SH1106 128x64"
reset_pin: D0
address: 0x3C
lambda: |-
it.strftime(20, 0, id(font1), "%H:%M", id(homeassistant_time).now());
it.printf(0, 58, id(font3), "%s", id(current).state);
it.printf(50, 58, id(font3), "%.1f ms", id(wind).state);
it.printf(114, 58, id(font3), TextAlign::CENTER, "%.1f°C", id(temp).state);
If the template says “regn” then you probably need to use a text sensor .
-J
palengh
(Pål Engh)
November 29, 2020, 7:14pm
3
Good idea, @JayElDubya , but I can’t figure out how the lambda string would be, then…
lambda: |-
it.printf(0, 58, id(font3),,, id(current).state);
According to some documentation I found it looks like the correct synth string would be
printf(int x, int y, Font *font, Color color, TextAlign align, const char *format, ...)
Then I get these errors while uploading:
Compiling /data/info_bad_vask/.pioenvs/info_bad_vask/src/main.cpp.o
src/main.cpp: In lambda function:
src/main.cpp:552:30: error: expected primary-expression before ',' token
it.printf(0, 58, font3,,, current->state);
src/main.cpp:552:31: error: expected primary-expression before ',' token
*** [/data/info_bad_vask/.pioenvs/info_bad_vask/src/main.cpp.o] Error 1
See if adding .c_str() helps:
it.printf( 0, 58, id(font3), "%s", id(current).state.c_str());
-J
palengh
(Pål Engh)
November 29, 2020, 7:36pm
5
That truly helped.
Text is displaying fine in the OLED
Still got this, though:
src/main.cpp:299:3: warning: multi-line comment [-Wcomment]
// lambda: !lambda "it.strftime(20, 0, id(font1), \"%H:%M\", id(homeassistant_time).now());\n\
And I got this: some seconds later
[20:34:50][W][homeassistant.sensor:014]: Can't convert 'Regn' to number!
Here is my entire lambda section
lambda: |-
are you using it as a text sensor?
palengh
(Pål Engh)
November 29, 2020, 10:31pm
7
Yes.
text_sensor:
internal: true
Is it still correct to use printf
as opposed to print
JayElDubya:
THANK YOU. I was very glad to find this.
Adding adding .c_str() helped me output text to an oled display from data stored in a global with type: std::string using %s as above.
I’m still looking for a way to assign initial_value: much easier than like this:
initial_value: “{‘w’,‘i’,‘f’,‘i’,’ ',‘c’,‘o’,‘n’,‘n’}”
and also for how to use globals.set: so assign a new value: on types std::string and char[]
