How do I remove iOS sensors
I have four iOS devices showing up, but we only have two iOS devices with the app installed. One phone was replaced with a new one, but the other showed up a second time, and I’m not certain why. I can’t seem to remove them. If I wanted to remove all iOS sensors, what is the simplest way to do it? Then I can setup the apps again to add the current phones. Thank you.
Try the Entity Registry under Configuration… if they still come back automatically after a restart you may have to remove them from there again then remove .ios.conf as well (with home assistant not running)
Thank you, I will give that a try.
I will add a way to disable sensors from within the app soon.
@robbiet480
Hi, does this way already exist? Because I did not find it :slight_smile:
I’m in the same boat, has anything changed?
Almost same issue here, I need to remove the old phone, and the new phone isn’t currently showing up.
Curious if any updates to delete the sensors have been made? In past I’ve just deleted the integration completely, removed the apps, and re added everything. Giant PITA!
