How do I remove this?
This “time” seems to be a unit_of_measurement of these sensors.
Are these your own template sensors?
If yes - why this UoM was defined?
Also, does it help if you change the format of the entity in the entities card?
See: Entities card - Home Assistant
If this is not your own sensor and you want to change it, you can change it with customize
, like so in configuration.yaml:
homeassistant:
customize:
sensor.your_sensor:
unit_of_measurement: 'hour' #or whatever you like
More info: Customizing entities - Home Assistant
Thank you both for these! You were both in a way correct.
I didn´t read integration documentation all the way trough…
I managed to set UoM the way I wanted.
