I’m detecting user interference (a user overriding an automation / setting lights to what they want) with the following in my configuration.yaml. I have a Wiz remote in my media room and it can change the lighting effect.
template:
- trigger:
- platform: state
entity_id: light.media_room_ceiling_light_group
attribute: effect
- name: "Media Room Ceiling Light Group Effect Context"
state: >
{% set c_id = trigger.to_state.context.id %}
{% set c_parent = trigger.to_state.context.parent_id %}
{% set c_user = trigger.to_state.context.user_id %}
{% if c_id != none and c_parent == none and c_user == none %}
physical
{% elif c_id != none and c_parent == none and c_user != none %}
dashboard_ui
{% elif c_id != none and c_parent != none and c_user == none %}
automation
{% else %}
unknown
{% endif %}
This works great, as expected. When a user touches a remote control to manually change the lights then the state changes to physical
My problem is that the state stays on physical
. Of course if an automation comes behind them then it will change to automation
If the user interacts with the lights again / a second time the sensor is not updated. It was already on physical
and since the most recent user interaction should make it go to physical
it doesn’t change.
I need the sensor to go back to a null string / nothing after a few seconds. I want to be able to detect the second user interaction with the lights.
Is there any way that I can have this template sensor revert to nothing / empty a few seconds after it changes to something?
