How do I reset the home assistant ? (mini PC)
I received a stand alone device with home assistant installed on in (mini pc). I did the initial setup but then it all went pear shaped & now I cant get back in with my username and password.
I would like to reset it and start again. It was doing update when it all went wrong.
If you want to blow everything away you can just follow the installation process. It details how to download HAOS onto a USB, and then boot from that USB to install.
ok, thanks
i was hoping to avoid doing that if possible, but may have to bit bullet on this.
ok, I found with help of my mini PC supplier the required command to reset home assistant app without having to wipe it completely.
(thankfully) up and running now.
