Hi, I am anewbie to HA
Based on the HA Documentation. I was successfully able to add my Xiaomi Air Purifier into HA UI
Also, I am able to Change the modes of the Xiaomi Air Purifier in HA UI using Inpuy Select & automation for each Input Select. (Working Great)
Question:
How do I control the Xiaomi Air Purifier Modes using Voice command thru google Home?
a. I am Able to Turn ON & OFF Xiaomi Air Purifier using the Phrase " Hey Google, Turn ON/OFF my Xiaomi Air Purifier"
But When i say “Hey Google, change mode to Auto/Faourite/Silent” Noting happens.
How do I control the Modes Xiaomi Air Purifier Modes using Voice command thru google Home?
The way around this would be to create a set of input_boolean that you can turn on and off via GH. You’d then need an automation that turns off all other input_boolean when one is turned on
You can create a script and expose that script.
You can then configure the home so that when you say your keywords it is basically saying turn on script
Hi, does anyone know if the Xiaomi Mi Air Purifier PRO is compatible with Google Home? After linking Mi Home account with Google Home it doesn’t appear… . Thanks in advance!
Hi, sorry, I’m new to this, I though this was a forum for the Google Home app, so no, I’m not using HA, I just notice this is an entirely different app, so, if I use HA I will be able to connect Xiaomi Mi Air Purifier Pro to Google Home? Thanks again!
