I’ve searched the forum and cannot find a simple way of setting a time on a card.
The input_datetime entity type , when clicking on it in a card, opens a ‘more info’ card which can then accept hrs:mins - but it’s a bit clunky. Is there no easy way to get a nice time input - like this:
I cannot find anything but it looks straight forward , no ?
I have seen attempts using sliders to set hours and minutes then some templating to create a ‘HH:MM’ label - not elegant is it?
Thank you, that is where I got the screenshot from indeed
Because I have a picture-elements lovelace card, that has an entity_label on it, and when I tap it, I want the time picker to appear as a popup, select a time, close the popup and store the time in another entity.
I know how to the the transfer of time to another entitiy , but I do not know how to open the picker when I tap the label on the picture element card - do you?
FYI - I am trying to emulate a central heating programmer, where a card can have 1.n instances of another card that has in it, the days of week, a on time and off time that the heating will be set on - for the specified days. All working bar the timer bit which now I have so thanks.
How does this browser mod enable me to popup a time picker. It only has 5 entity types none of which enables a card to be displayed (as in the timer picker)?
EDIT:
Sorry, it’s easy . I should have read the instructions more.
