How do I set the value of a sensor?
I’m trying to implement a “dual rate” tariff. I believe that there is a bug in the current Utility Meter integration (I’ve no idea how to quote this assumption - but this is not relevant to my question except to prevent answers along the line of “I should use the Utility Meter Integration” - which I’d love to).
This is a snippet from my /config/configuration.yaml:
template:
  - name: "dual rate tariff"
    state: "0.00"
    unit_of_measurement: "£"
Which I would like to update via an Automation.
The “Turn on Blue LED” is just a debug device to test that the trigger is working. I would now like to add another action to set the value in my Template Sensor (is that the correct description?) to a numeric value.
How do I do that?
Thanks in advance, Martin
You can’t set a value of a sensor. Sensors are read-only.
Alternatively, you can use number helper:
https://www.home-assistant.io/integrations/input_number
…/Frenck
Thanks Frank,
One more gem in my HA library…
Regards, M.
