How do I set up home assistent so I stop getting the This site can’t be reached issue
Anyone have an eero 6e mesh system and getting the This site can’t be reached issue ERR_ADDRESS_UNREACHABLE in the browser when trying to login?
I’m unclear as to exactly DHCP changes I need to make to resolve the annoying issue?
Are you able to physically log in system and look at your IP settings? That should be a start.
Ideally, DHCP should just give everything out as you have it set up for other devices.
Yes, I can log into the eero and see the ip settings. It;s connected via LAN (wired) and I see the IPv4 with the IP address I use to connect and I see the IPv6 settings. There is also a place where I can Add a reservation (IPv4 reservations & port forwards) along qith IPv6 “Add a firewall rule”
Can you log in to the HA device? Ideally you should have it set to a static IP or reservation.
