Hello. I can’t measure gas consumption directly at my property. So my strategy is to measure how long the led is lit when the boiler is active, using a light sensor driving a GPIO pin, and estimate it from that.
This doesn’t work:
- platform: pulse_width
pin: D1
device_class: gas
accuracy_decimals: 1
update_interval: 1s
- platform: integration
name: "Total Gas On Time"
sensor: gas_sensor
time_unit: min
pulse_width
measures the time the light is on. But it holds that value until the next pulse. So the integrator is constantly accumulating the last measured duration.
I tried passing a binary_sensor
to integration
, but that choked.
I’ve seen solutions (e.g. here) using the History Stats component in Home Assistant, but I was hoping to do it on-device if possible to keep things as decoupled as possible.
I’m new to Home Assistant and ESPHome and this may be obviously doable, or obviously impossible but I can’t see it. Any guidance?
(P.S. I will want daily totals - either by resetting the total on-device at midnight, or in Home Assistant).
Many thanks.
UPDATE
I have a working solution combining ESPHome and Home Assistant as follows:
ESPHome:
binary_sensor:
- platform: gpio
pin: D8
Home Assistant configuration.yaml
- platform: history_stats
name: Gas ON today
entity_id: binary_sensor.gas_sensor
state: "on"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0) }}"
end: "{{ now() }}"
