I can turn the effect off from Home Assistant, but I can’t find a valid entry for a light.on command to say disable the active effect if there is one in my config.
Log showing it turn off from ESPHOME
[10:50:45][D][light:035]: ‘Left Top’ Setting:
[10:50:45][D][light:046]: State: ON
[10:50:45][D][light:084]: Transition length: 1.0s
[10:50:47][D][light:035]: ‘Left Top’ Setting:
[10:50:47][D][light:108]: Effect: ‘Flicker’
[10:50:53][D][light:035]: ‘Left Top’ Setting:
[10:50:53][D][light:084]: Transition length: 1.0s
[10:50:53][D][light:090]: Effect: ‘None’
Example config:
- light.turn_on:
transition_length: 3s
red: 100%
green: 71%
blue: 43%
brightness: 100%
Is there something I can add to tell this specifically “No effect, if one is applied, turn it off?”
So far I’ve tried:
effect: None
effect: 'None'
effect: False
effect:
effect: Null
and all give me a “Failed Config” message when I attempt to compile.
Is there a way to do this? Thanks!
jsuanet
(Jos)
March 9, 2022, 10:34am
2
If I use the following syntax, I don’t get an error message…
on_turn_on:
- light.turn_on:
effect: "None"
brightness: 75%
That worked! I’m assuming it’s because I’d done single quotes before, I’m surprised I didn’t try double as well.
Thank you
Dizzwold
(Darren)
September 15, 2022, 4:08pm
4
@jsuanet
I’m trying to accomplish something similar to the above with RGBCCT 5-in-1 Ledsand a slow rainbow effect and color interlock. I have the following, but when I switch to the white leds, the white leds stay on for the set duration of the effect previously selected, then revert back to changing colour again. I’d like it so when I select the white leds to On (or triggered at a later date by a sensor), that it switches Off the effect and stays on white util I set it back to colour.
Could you offer some help?
- platform: wifi_signal
name: "WiFi Signal $devicename"
update_interval: 60s
output:
- platform: ledc
pin: 26
frequency: 25000Hz
- platform: ledc
pin: 18
frequency: 25000Hz
- platform: ledc
pin: 19
frequency: 25000Hz
- platform: ledc
pin: 23
frequency: 25000Hz
- platform: ledc
pin: 05
frequency: 25000Hz
light:
- platform: rgbww
name: "Kitchen Colour LEDs 2"
warm_white: ledc_ww
cold_white: ledc_cw
red: ledc_r
green: ledc_g
blue: ledc_b
cold_white_color_temperature: 5000K
warm_white_color_temperature: 3000K
color_interlock: true
effects:
- lambda:
update_interval: 16s
lambda: |-
static int state = 0;
auto call = id(kcl2).turn_on();
call.set_transition_length(15000);
if (state == 0) {
call.set_rgb(1.0, 0.0, 0.0);
} else if (state == 1) {
call.set_rgb(1.0, 0.5, 0.0);
} else if (state == 2) {
call.set_rgb(1.0, 1.0, 0.0);
} else if (state == 3) {
call.set_rgb(0.5, 1.0, 0.0);
} else if (state == 4) {
call.set_rgb(0.0, 1.0, 0.0);
} else if (state == 5) {
call.set_rgb(0.0, 1.0, 0.5);
} else if (state == 6) {
call.set_rgb(0.0, 1.0, 1.0);
} else if (state == 7) {
call.set_rgb(0.0, 0.5, 1.0);
} else if (state == 8) {
call.set_rgb(0.0, 0.0, 1.0);
} else if (state == 9) {
call.set_rgb(0.5, 0.0, 1.0);
} else if (state == 10) {
call.set_rgb(1.0, 0.0, 1.0);
} else if (state == 11) {
call.set_rgb(1.0, 0.0, 0.5);
call.perform();
state++;
if (state == 12)
state = 0;
jsuanet
(Jos)
September 16, 2022, 1:56pm
5
Sorry, I don’t have any experience with RGBCCT leds.
Dizzwold
(Darren)
September 17, 2022, 5:36pm
6
Hi @jsuanet ,
Okay, thank you for taking the time to reply.
Darren.
