Home Assistant 0.84.4 provides tellduslive 0.10.4, but I need a fix that I believe is in a later release. How do I upgrade that dependency for HA?
depends on how you have installed homeassistant (hass.io, docker, python virtual environment etc).
for me (I dont have tellduslive in my system), it would be:
$ sudo -u homeassistant -H -s
$ source /srv/homeassistant/bin/activate
$ pip3 install --upgrade tellduslive
But Iām not sure this will fix things for you - your link suggests the fix is in homeassistant not tellduslive?
Thanks! I use pip3 install homeassistant
to install HA on a mac. Iām unable to find the activate
binary, thoughā¦
Activate is from a linux virtualenv install.
Assuming you installed on a mac as listed here https://www.home-assistant.io/docs/installation/macos/ - you dont need to āactivateā - or sudo to the homeassistant user.
so just try ```
but I suspect it wont help
That will only upgrade the āglobalā dependency, but not the one inside ~/.homeassistant/deps
Depends on your installation method.
walaj@JonLabNUC:~$ cd ~homeassistant/.homeassistant/deps/
walaj@JonLabNUC:/home/homeassistant/.homeassistant/deps$ ll
total 8
drwxrwxr-x 2 homeassistant homeassistant 4096 May 1 2018 ./
drwxrwxr-x 12 homeassistant homeassistant 4096 Dec 27 15:39 ../
I think
pip install --target ~/.homeassistant/deps/lib/python3.9/site-packages/ --upgrade <package>
should do it.
