How do I use a service
So I’ve been reading a bunch and doing a bunch, but I’m still missing something. So if I go into developer tools and set up a service call, and call it successfully, what do I do with that yaml? How do I USE or REFERENCE a service? All I can find just shows running it in the Developer Tools. Seems like I should be able to give it a name and invoke it from something.
In an automation:
    - service: switch.toggle
        entity_id: switch.mechanical_bench
In a script:
  sequence:
Thanks so much. It is so simple and yet I couldn’t find it. So apparently it is sort of an “in-line” kind of thing and not something that can be named and reused. Although I guess once it is in a script or automation, then you can used that named thingee.
If you have a bunch of services you use regularly in different places, put the sequence in a script. You can pass variables to scripts.
All of that script syntax can be used in automations too (automations are just scripts with triggers).
For example you could create a script to make announcements and pass the message and where to announce it to to the script.
