I’m trying to write a script that uses repeat for_each to iterate through all entities of the domain “timer” but googling and trying for 30 minutes left me with nothing. I can easily write something in developer tools → template that will list the desired entities, but this won’t work with for_each.
When nailing that, I intend to pause timers that have less than 5 mins left or unpause paused timers. Reason for this is to keep timers from finishing while HA restarts.
I recall an issue while trying to create a helper that contained a list of WiFi devices on my network. I’m sorry I can’t remember the explanation in perfect detail but the gist of it was that the output of the list template function didn’t output the list in a JSON compatible format?
I think I had to use replace functions to replace double quotes (") with single quotes (') and use the to_json function to convert the array into a JSON compatible one? That list could then be parsed correctly.
Unfortunately I ended up just calling the template directly in a markdown card rather than saving it in a helper so the template I had for converting all items in the device_tracker domain to a JSON list is long gone. I will have a look around the forums and see if I can find anything related to it, but hopefully this will push you in the right direction or others might add onto this.
