The other triggers seem… not applicable? Under “Entity” I get a choose of “State” and “Numeric State” but neither of them offer anything when searching for “Livarno”.
I am so confused. What am I missing / supposed to see on the ZHA device page, to let me create an automation for this button?
And more concretely to let me solve this problem; how do I make a trigger for the button on and button off?
Find the button in the list and toggle it to see what states it gives you, this should give you a clue if not post what it says in states and someone will point you in the right direction
Ignore the states for now. Follow @tom_l’s suggestion and use an event for your automations.
If you’re lucky, you might find someone has already created a blueprint for your exact device model.
If not, it should be pretty easy to modify the closest blueprint you can find via the UI if you’re on the latest version of HA, and adapt it to fit your model.
Now the automation should react to the button press. Here’s the full yaml for one of my Livarno buttons:
alias: Turn off media center
description: ""
- platform: event
event_type: zha_event
event_data:
device_ieee: 2c:11:65:ff:fe:57:dd:6d
command: "off"
condition: []
- type: turn_off
device_id: 2a68672f0cdc556b05a40787e614afb5
entity_id: switch.lumi_lumi_plug_maeu01_switch_2
domain: switch
mode: single
There is just no way that this is supposed to be the intended way of hooking up a trivial button-press automation, but… here we are. Disoverability in the UI is not great.
