I have a method that will tell me if any of the lights are on in my shed and I’d like to be able to turn them all on or off. About half are lights and the other half are switches. Is there an introspective way that I can all the appropriate off service for entity in the array? This is a step in learning to better templatize more of my rooms.
The code below doesn’t work, but it what I have.
toggle_shed:
alias: "Toggle Shed Lights"
variables:
action_type: >
{% if is_state('light.shed_lights', 'on') %}
"{{ 'light.turn_off' }}"
{% else %}
"{{ 'light.turn_on' }}"
{% endif %}
sequence:
repeat:
for_each:
- "shed_north_light"
- "shed_south_light"
- "shed_east_light"
- "shed_west_light"
- "shed_outside_light"
sequence:
- service: "{{ action_type }}"
entity_id: "light.{{ repeat.item }}"
petro
(Petro)
June 26, 2023, 1:53pm
2
just make a light group and call light.toggle
- service: light.toggle
entity_id: light.shed_lights
If you’re dead set on a template, you don’t need a foreach. Just provide an entity_id list.
Secondly, make sure you understand when to use quotes and when not to. Overquotting will cause issues.
toggle_shed:
variables:
action_type: >
light.turn_off
{% else %}
light.turn_on
{% endif %}
object_ids:
- shed_north_light
- shed_south_light
- shed_east_light
- shed_west_light
- shed_outside_light
entity_ids: >
{% set ns = namespace(items=[]) %}
{% for o in object_ids %}
{% set ns.items = ns.items + [ 'light.' ~ o ] %}
{% endfor %}
{{ ns.items }}
sequence:
entity_id: "{{ entity_ids }}"
Also, if light.shed_lights
has all your lights, you can do this (again if you’re dead set on using templates)
toggle_shed:
variables:
action_type: >
light.turn_off
{% else %}
light.turn_on
{% endif %}
entity_ids: >
{{ expand('light.shed_lights') | map(attribute='entity_id') | list }}
sequence:
event further simplified…
toggle_shed:
sequence:
- service: >
light.turn_o{{ 'ff' if is_state('light.shed_lights', 'on') else 'n' }}
entity_id: >
stevemann
(Stephen Mann (YAML-challenged))
June 26, 2023, 1:59pm
3
I thought I was alone in making a simple project complex… Just make a shed group.
Automation:
service: homeassistant.turn_off
data: {}
entity_id:
- group.shed
Thanks for taking the time. This works great!!!
Thanks for answering. This is useful. I’ll look at using groups.
