I am trying to write a bit of yaml code to read and display the charging state of an EPEver PWM Solar Charge controller. So far, so good. But I am now stuck on how to turn the number returned into one of four strings. My code is below and the sensor name is: “Charging Mode” (the last one).
Regards, M.
This looks like an ideal place to use a lambda - a chunk of code written in C(++) that gets inserted by the YAML-to-C conversion process that occurs during the ‘compile’ phase of ESPHome processing.
While I can’t discern from your comments exactly what you want it to do, it appears that you want to have a set of bitwise comparisons, and return a pointer to one of the strings as a result of the matching comparison.
If you are not comfortable writing in C, perhaps if you add more details about the desired comparisons here, one of us will be able to compose the lambda for you.
Thank you for the offer of help, that would be most welcome.
If I understand what I’ve got so far, by the end if this snippet of code, something/somewhere holds value of the register at 0x3201. By masking that value by 0x0C, I now have a result that is 0, 1, 2 or 3.
- platform: modbus_controller
modbus_controller_id: ls1024b
address: 0x3201
unit_of_measurement: ""
register_type: read
value_type: U_WORD
bitmask: 0x0C #Mask off all but D3 & D2 using 0000 1100
accuracy_decimals: 0
Now the bit I can’t get, is to map each of those value to 1 of 4 strings. So that when the sensor returns 0, the Dashboard displays the string “No Charge” and when the sensor returns 1, the dashboard displays “Float” etc.
If I was doing this in the Arduino/ESP32 world, I’d do something like this:
switch (value_in_modbus_map_address_0x3201) {
case 0:
Serial.println("No Charge");
break;
case 1:
Serial.println("Float");
break;
case 2:
Serial.println("Boost");
break;
case 3:
Serial.println("Equalizing");
break;
default:
Serial.println("Error");
break;
a case statement would be the most natural way to express this function, but don’t underestimate the power of a simple if/then/else cascade when it would suffice.
Case/switch statements are great when there are many cases, especially if the cases are hard-codable (e.g. ‘5’) but for stuff that has a computed result (e.g. if x&0x3|0x4), an if/else cascade might do for short lists of tests.
I’ll take a look at your testing requirement and see if I can conjure up a simple lambda that could do the trick. (Might take me a while, with distractions …)
In ESPHome you don’t ‘print’ things, but you return strings to something like a text_sensor which reports them to the device’s webpage or to HA or via the web API.
So the lambda should actually be embedded within something like a text_sensor for that reason.
… and so on with other values for Bit3Bit2, and other logic, perhaps bitwise tests instead of simple equality tests.
The idea here is that the ‘value’ of the text_sensor is provided to it by the lambda which performs a set of tests and returns [a pointer to] the one string that represents the current state.
What you (or HA) do with that text is up to the rest of the YAML code.
Sorry, this is a very rough-edged explanation, but perhaps it gives you a direction in which to proceed, and an example of what that path looks like. More can follow, as we converse further.
(and, BTW, I got the indentation totally wrong - this won’t work if pasted into YAML. My goal here is to show you the general idea and help you to work it in as you see fit.)
Thank you, this is really appreciated. But first the basics!
How to I structure the yaml? In my code (as shown earlier), I think I have a sensor: with multiple inputs: id: charge_current,id: charging mode etc. What would be the relationship between a sensor: and a text_sensor or a binary_sensor etc. Would a text_sensor: be a subsidiary to sensor:? Like so:
- platform: modbus_controler
#rest of top_level_sensor
text_sensor: #indented from sensor:
- platform: #where are the lists of "platforms"?
#end of sensor definitions
Lastly, how do I pass variables between a sensor: and a text_sensor:?
If I am collecting the data I want (which I am) from a sensor:, I will need to process it in a text_sensor:?
Sorry if this is so basic. But despite looking (long & hard) I can’t find an expressive explanation of esphome/yamal programming.
A Global variable might be useful if you need to have multiple integrations handling the value.
e.g. the modbus platform fetches it, and the text_sensor platform ‘displays’ text based on its value.
To use Globals, your sensor will probably have to also use a lambda to store the value in the Global so the text_sensor can access it.
Programming something in the ESPhome enviroment can be challenging if you (like me) are used to ‘just writing it in C’ (or any other object/proocedural language). I had to just read, explore, get lost, read more, get lost more, and keep repeating that on the web docs before it started to mesh. And I still get lost whenever trying something new. Eventually, though, it starts to make sense.
Another path that might work is to define a Custom Sensor for this. (I will have to go read to learn what a modbus is/does to offer better suggestions.
Right on the modbus_controller page is an example where a text_sensor is defined and uses the modbus_controller platform.
That led me to think there might be a simpler solution…
(So I may be closing in on understanding your goal a bit better, and it looks like this is the component you want to define.)
Within it is a place where you’d stick the lambda we started sketching out above. So the value (pointer to the text string) returned by the lambda becomes the text_sensor’s ‘displayed’ value.
(the search feature on the ESPHome page seems to be broken at the moment, making it harder to find all the pieces that might relate to lambdas and their use, but the starting point is the ‘Automations’ link on the home page, and then all the bits about lambdas is along the navbar to the left.)
I have taken that example and “pushed” it around to look a bit like the sensor that works and this is as far as I have got:
text_sensor:
address: 0x3201
register_type: read
name: "Charge Mode (as text)"
bitmask: 0x0C
#How do I inspect my "working value" at this point? Where is it held?
raw_encode: HEXBYTES # What does this do? No hit from Google!
lambda: |-
uint16_t value = modbus_controller::word_from_hex_str(x, 0);
/*can you strip the above down for me? My guess it that it reads something like this...
The variable "value" of data type 16 bit unsigned int is assigned the
value of the function "word_from_hex_str(x, 0)"
But what is the definition of "word_from_hex_str(x, 0)"
... and WHAT is "x"
// value = <0 | 1 | 2 | 3 | 999>; #If I do this, I can confirm the switch statement
switch (value) {
case 0: return std::string("Not Charging");
case 1: return std::string("Float Charging");
case 2: return std::string("Bost Charging");
case 3: return std::string("Equalizing");
default: return std::string("Unknown");
return x;
//Return to where?
So.
Question 1. How to I debug this code? My suspicion is that I should somehow pipe to the logger but I can not find any clues as to how this can be done.
Question 2. The Switch-Case is working. But the problem is that the preparation of “value” is wrong. Are there header files somewhere that are defining all the functions and instantiation parameters of the modbus_controller class?
Question 3 How can I just get the result from the bitmask: 0x0C into “value”? Should be simple but its driving me nuts
In lambda’s, when they are provided-for by the module (as this one is, with the ‘lambda:’ line) ‘x’ is the value that the platform ‘read’ from whatever source it’s set to.
So in this case, ‘x’ is your raw value - the one you want to do the bitwise parsing on in order to select a string to return.
The thing (in this case, a pointer to a string, because it’s within a text_sensor) that you return becomes the present ‘state’ of that object (the text_sensor). It’s what the thing then displays as its state.
First, set ‘raw_encocde’ to ‘NONE’ so ‘x’ will contain a simple integer value on which you can do bitwise operations.
Then you don’t need word_from_hex_str().
Then, to simplify, just try making your switch statement be ‘switch (x)’
or, if you need to mask the value to act on only certain bits, do some bitwise math on it, as in:
‘switch(x & 0x03)’ to mask all but the last two bits from which you will select what you want your case to choose.
The thing is, do the bitwise selection in the switch statement’s argument, in conjunction with the values you choose for the cases, or both, as appropriate. I hope you’re comfortable with bitwise operators.
However, after another 12hrs of playing, I think I have a “catch 22” problem!
1.The physical register that I wish to read contains a 16bit big-endian integer.
2. The ESPHome “sensor” will correctly read the value. But a Lambda within this sensor will not allow a return operation containing a string.
3. The ESPHome “text_sensor” will not read the integer from the modbus controller. Returning NaN. Although it will allow a return datatype of String.
How can a lambda behave like a genuine C++ function with defined return types:
Then it looks like the modbus platform returns a string (pointer to a string) as ‘x’ (I hate it when module definitions aren’t clear about what a parameter like ‘NONE’ does), so you will need the line below after all. You had asked what it does earlier. It accepts a [pointer to a] string (x, supplied by modbus) and returns a (binary) integer into ‘value’ which you can then use in your tests.
and probably also the
as you had in the code sample you posted earlier.
Then, do your bitwise tests on ‘value’ instead of ‘x’.
And, if it’s big-endian and you only need to test the rightmost 2 bits, just mask the rest by
switch(value & 0x03)
and test for 1, 2, or 3 in the switch cases.
If, however, the endian-ness is otherwise and you need to test the rightmost 2 bits of the first byte, just insert this before the ‘switch’ statement:
value = value >> 4;
Which (if I can remember my bitwise operators ) will shift the bits you need into the lower byte, making the switch tests work as intended. And, I believe the statement can be simplified as
value >>= 4;
but don’t hold me to it.
Of course, you could instead just test the string (x) contents, but that would be messier, and can be prone to programmatic/logic errors.
Regarding this: the lambda returning a string has to be in a ‘text_sensor’ component, not a ‘sensor’ component. By virtue, text_sensors want to be supplied with [pointers to] strings, not binary values.
So, stepping back to your YAML, you’d use 'sensor’s for most of the other values you’re reading from modbus, but will need to use a ‘text_sensor’ as the module-type for the one where you want it to display a string.
Thank you for the constant stream of good idea’s that you are prepared to offer…
While I work through your last, can I throw in a couple of curved-ball questions?
Is ESPhome the simplest place to implement my solution? For example, instead of coding in the ESP8266, could it not be achieved in a “Dashboard” somehow?
When I installed Home Assistant on my Pi, it somehow magically found my network printer (HP Office Jet Pro 8600) and on the Overview Dashboard there is an Entities Card which contains an entry that shows printer state in words: “Idle”, “Printing”, “Error” etc. Is it possible to find and inspect this sensor’s yaml for clues?
There are a number of ways and places where your solution could be implemented.
I still believe that the text_sensor will be the most useful path.
Just gotta puzzle out the parsing of that bit-packed return value is all.
You’re about 1 step from having that working, I believe.
The printer component probably has its state strings embedded in the C code, much as we’ve been doing in your case.
Thank you, I’m ready to try any approach…
What context is this snippet in? Not having a lot of luck understanding how it is used!
Here is (what I hope is the relevant) part of my ESPHome .yaml:
address: 0x3201
register_type: read
value_type: U_WORD
# D3D2 = 0x00 = "No Charge"
# D3D2 = 0x01 = "Float"
# D3D2 = 0x02 = "Boost"
# D3D2 = 0x03 = "Equalizing"
sensors: ##################Red X "sensors is invalid option for..."
name: "Komfovent On Off"
unit_of_measurement: "State"
value_template: >- ###########Red X "value_template is invalid option for...."
{% set mapper = {
'0' : 'Off',
'1' : 'On'} %}
{% set state = states(sensor.komfovent_on_off) %}
{{ mapper[state] if state in mapper else 'Unknown' }}type or paste code here
#end of file...
…or should your snippet be added to a Dashboard Card?
The map (part of a template) would replace the lambda. But not by just pasting it over, you’ll have to adapt it to fit into a sensor and use what your sensor returns.
Be advised that if you go the template route (versus lambda) you’ll be in a whole 'nother language.
A template might be the best and easiest path for this in the end.
Getting templates right has, for me, always been a nightmare. I’d be unable to assist much.
Okay, staying with lambda, can you tell me how to examine variables within (and hopefully outside) the lambda construct? This is the minimal snippet that I’m working with. Line 75 is not happy - I guess that “word_from_hex_str()” is not returning the correct datatype?
How do I find what other functions “modbus_controller” has? Then once I have an integer in “local_var”, how do I display? See line 77.
