I can’t seem to access the command line, all the documentation says that it should be be from typing in http://IP_ADDRESS:8123/api/ but that doesn’t seem to work for me
I am quite confused, I use HA supervised on a raspberry pi 4.
Documentation: REST API | Home Assistant Developer Docs (home-assistant.io)
From the link:
For example:
rest: - resource: http://homeassistant:8123/api/hassio/supervisor/stats verify_ssl: false headers: Authorization: !secret ha_api_token ### <---- THIS Content-Type: application/json scan_interval: 29 sensor: - name: "Supervisor CPU" value_template: '{{ value_json.data.cpu_percent|round(2) }}' unit_of_measurement: '%' - name: "Supervisor RAM" value_template: '{{ value_json.data.memory_percent|round(2) }}' unit_of_measurement: '%'
