So I can access my camera using the token and url in HASS.io directly, and I’ve added it to a card in lovelace.
But, if I try to add it to Motioneye (Hassio in Docker / Ubuntu 16.04) I get SSL certificate problem: unable to get local issuer certificate
No idea why. I’m accessing my instance through Apache Reverse proxy with SSL enabled and it works just fine, but no camera connection. Is the ESP32Cam not supported in Motioneye?
