How do you configure automation for 5 hours from switch or after a reboot HA
so i have issues… my code works if you press button to turn on and off hot water tank… and my automation shuts it off 5 hours to save electricity… but if i reboot Ha during the time its on it wont work it will keep it on…
i tried adding trigger home assistant and then condition of hot water tank switch on for 5 hours
so once hA boots and hot water tank is on for 5 hours it would shut off
but it didnt work…
how can i add that it still work?
here is the code i use for the switch… i did tried just switch and a condition of 5 hours but that didnt work … i tested it by using hot water tank switch on state for 5 seconds but it never turned off… so wasnt able to get conditions to work right…
so i want to be able to press button or when you reboot home assistant… that the automation checks if hot water tank was on 5 hours then turn it off
alias: Turn off  Hot Water Tank after 5 hours
description: ''
  - platform: state
    entity_id: switch.mitchs_hot_water_tank
    for:
      hours: 5
      minutes: 0
      seconds: 0
      milliseconds: 0
    to: 'on'
  - platform: homeassistant
    event: start
condition: []
  - service: switch.turn_off
mode: single
i tried this to work but it wont work i tried the hours to 5 or 0 below didnt help
description: ''
  - platform: state
    for:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 0
    event: start
condition:
  - condition: device
    type: is_on
    device_id: 9d241cf92747c4bef591d585192ff2de
    domain: switch
    for:
      hours: 5
      minutes: 0
      seconds: 0
      milliseconds: 0
mode: single
Here is an example automation that will be more reliable way of ensuring a set of actions occurs that will with stand HA restarts, etc
  - alias: Automatic Door Lock
      - platform: state
        entity_id: lock.door
        to: 'unlocked'
      - platform: time
        at: input_datetime.door_lock
        event: start
      - platform: event
        event_type: automation_reloaded
      - choose:
          - conditions: "{{ trigger.platform == 'state' }}"
            sequence:
              - service: input_datetime.set_datetime
                entity_id: input_datetime.door_lock
                  datetime: >
                    {{ (now() + timedelta(minutes = 30)).timestamp() | timestamp_local  }}
          - conditions:
              - "{{ trigger.platform == 'homeassistant' or trigger.platform == 'event' }}"
              - "{{ as_timestamp(now()) - as_timestamp(states('input_datetime.door_lock')) < 120 }}"
              - "{{ is_state('lock.door', 'unlocked') }}"
            sequence:
              - service: lock.lock
          - conditions:
              - "{{ trigger.platform == 'time' }}"
            sequence:
just substitute your entities, etc in the above and change the “minutes=30” in the timedelta functron to what you want it to be (5 hours = 300 minutes)
it seems a bit complicated and you will need to first create an appropriately named input_datetime but it’s the most reliable method for ensuring things operate as expected.
@finity
I think this would also work in your automation:
      - choose:
            sequence:
                  datetime: >
        default:
          - condition: template
            value_template: >
              {{ now().timestamp() >= as_timestamp(states('input_datetime.door_lock')) and
The default consolidates the last two conditions in your original example. I think I got the logic right (please let me know if I got it wrong). When triggered by restart/reload/time, if the current time is greater than the input_datetime (and the door is unlocked), then lock the door.
the only thing it looks like it is missing is the “grace period” of 120 seconds.
But you would know better than me since I (mostly) took this from one of your suggestions in the other thread with tinkerer’s edit.
(EDIT: actually it’s his edit and later mine that added the two additional conditions. I’ll need to look at it more closely but I think you’re probably right. Sometimes I like to get a bit more verbose to increase my own readability and since it was a evolving automation I didn’t catch the overlap.)
ah ok ill give them a try and see how it works i appreciate it…
for now what i did was 2 automations one that when HA boots up and condition is hot water tank on shut off 5 hours from then… or the button press but thats if ha doesnt reboot… be nice a better intergration automation not so complicated
but ill check out that other link and stuff
