How do you configure state change updates?
How can you configure how states are reported and graphed?
I have a sensor for light level and this appears to log and graph the light level each time the state is requested even if the state / light level is the same as last time :
but other sensors, including a target temperature below, only appear log and graphs the state when the state has changed and if the state, in this case temperature, has not changed in a long time the data / graph wont change:
For the target temperature I would like it to show the clear jumps in target temperature changed as the thermostat is adjusted. it does not make sense for this graph to show a diagonal line making it appear that the target temperature was gradually ramped up over a long time as apposed to what really happened which was the target temperature was suddenly changed from 1c to 19.5c and then it stayed at 19.5c for some hours.
what do I need to update in order to configure this?
