I need some ideas as I’m just a layman and help with programming.
I want to operate my sauna with a three-stage heater; each Heistab 2400W is controlled via a corresponding relay.
My goal would be to use a helper in Homeassistat to define how many heating circuits should be used.
The default value is transmitted to ESPHome (Mode 1 - Relay 1, Mode 2 - Relay1 & Relay2, Mode 3 - Relay 1 & 2 & 3).
I can already read the value with the following code:
- platform: homeassistant
name: "Sauna Performance From Home Assistant"
entity_id: input_number.Sauna power
However, I don’t know how I can process this value further.
Process it how? Have you defined the relays on the ESPHome device? Then you simply use an on_value: automation attached to your homeassistant: sensor to turn your relays on and off as required.
Then that would be a Yes. That is exactly what I described and asked if that’s what you were asking. A and B or A + B + C that’s what you call a combination. So you make an Input Select and you’re going to need a bunch of if-then statements that cover each possible choice. If - mode1 then - turn_on Heat A
This is all covered and has examples in the Docs under Automations
