How do you extract state status from MQTT Cover?
I’ve got an MQTT Cover from which I’d like to extract state status to show basic open/closed verbiage.
cover:
  - platform: mqtt
    friendly_name: Garage
    state_topic: "garage/door/status"
    command_topic: "garage/door/control"
    payload_open: "OPEN"
    payload_close: "OPEN"
    # payload_stop: "OPEN"
    state_open: "OPENED"
    state_closed: "CLOSED"
    optimistic: false
    retain: true
    value_template: '{{ value }}'
How do I do this?
I did it through a template sensor like so:
Looks like this
Nice, thanks!
How do you have the dark theme applied?
Maybe you can use the option mqtt statestream, published in version 0.54.0
https://home-assistant.io/components/mqtt_statestream/
In your configuration use the frontend: tool
then I just searched in the themes area of this forum to find some setups other folks have created. This is the one you see:
Never knew you could theme your HA…there goes more time spent in HA
Can you paste your frontend.yaml, or its code as code instead of a screenshot?
My mostly updated Home Assistant. Feel free to peruse and use anything you like.
I have the same basic question. To which topic does the value_template section apply? I set a value for the value_template hoping it would extract into the state but it appears to have extracted into the availability.
