i only have one automation in node red
[{"id":"7a05c8ff9a342ae7","type":"switch","z":"1378e93887bb0d10","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":100,"wires":[["4a97105a2093ba3d"],["63d6b3f051e52ab4"]]},{"id":"ea7c5316171c6f5e","type":"server-state-changed","z":"1378e93887bb0d10","name":"Basement Center Light Come On With 3way","server":"915baa48.9b1898","version":6,"outputs":1,"exposeAsEntityConfig":"","entities":{"entity":["switch.basement_lights_3way"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":170,"y":100,"wires":[["7a05c8ff9a342ae7"]]},{"id":"4a97105a2093ba3d","type":"api-call-service","z":"1378e93887bb0d10","name":"Center Basement Light On","server":"915baa48.9b1898","version":7,"debugenabled":true,"action":"switch.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.basement_center_light"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_on","x":660,"y":60,"wires":[[]]},{"id":"63d6b3f051e52ab4","type":"api-call-service","z":"1378e93887bb0d10","name":"Center Basement Light Off","server":"915baa48.9b1898","version":7,"debugenabled":false,"action":"switch.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["switch.basement_center_light"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":false,"domain":"switch","service":"turn_off","x":660,"y":120,"wires":[[]]},{"id":"915baa48.9b1898","type":"server","name":"Home Assistant","version":6,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":["y","yes","true","on","home","open"],"connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"d412ca81879af902","type":"global-config","env":[],"modules":{"node-red-contrib-home-assistant-websocket":"0.80.3"}}]
other then that no automation
so if i toggle the switch at the light itself no glitch
but when i toggle
then it causes the light to turn on and off also turns on and off the led on the light switch itself i noticed
but if i turn on the switch but actually pressing the button it doesnt start flicking on and off… and i not sure when this started if one of the HA updates buggered it up or what not
