i have a RPI4 i use gpio pin 22 as a Trigger button to an Arduino that treats it as a Mometary swtich a OFF ON OFF to activate and OFF ON OFF to decativate… and gpio pin 24 is Reading the state
i have tried several configuartion then reading there is no fix for RPI4
but how do i stop RPI4 triggering the Arduino at reboot
if the ardunino is ON and you reboot HA it triggers the switch and deactivates
what i doing wrong
cover:
- platform: rpi_gpio
state_pull_mode: “UP”
covers:- relay_pin: 23
state_pin: 24
- relay_pin: 23
#switch:
invert_logic: true
ports:
23: Water Valve # Sauna Water Pump Home Assistant Toggle Switch To Activate Pump with Arduino
switch:
invert_logic: true
#state_pull_mode: "UP"
ports:
binary_sensor:
invert_logic: false
ports:
24: water_position # Sauna Water Pump Valve Sensor Postion On/Off (Open/Closed)
