so ever 3 configuration restarts of HA it triggers my Ardunino
on there i have a routine to create a Mometary switch
so OFF ON OFF to simulate you pressing a mometary switch
but each time i reboot 3 times or restart configuration it will go HIGH each time i guess
and i have used
invert_logic: false
but it doesnt matter because HA still triggers the GPIO and all it does is triggers it opposite direction
so no matter what you do it Triggers GPIOS
how do i say like i could with Raspbarian on a reboot GPIO Low=13 as example id configure it in rc.local
so each time you boot up pi it makes ure GPIO is set low not high
how do i do that in HA i cant find it under GPIO to set it to LOW so it cant trigger the GPIO ever
im also using the RPI 4 4GB version if that matters
ok so im using GPIO 23 says down
so i need to change it to a like GPIO8 to up
so that way it cant trigger the switch then
and then do i rem out invert_state: false
ill try that now and see how it works… thank you been driving me nuts for a while
so how my Ardunino works is setup as a Push Button Mometary
So LOW for OFF and HIGH for ON
so be like
LOW HIGH LOW = 1 press of a Button (Released, Press Button, Release Button)
and basiclly each time i restart HA
is like
LOW
Restart HA ===>then HOlds Button Down (Goes High)
Restart HA ====> releases Button and activates Ardunio
Restart HA ====> Holds Button Down again
Restart HA =====> Releases Button and deactivates Ardunio
basiclly is whats going on
i didnt try it yet… so is Pull down LOw or High?
so if that doesnt fix my issue what would it be then
and how i have it wired is. Gnd wire from Arduino ground to Raspberry Pi GND
and i run a wire from GPIO Arduino to GPIO Raspberry Pi
just just a direct wire with a Resister in between
