So normally you would write a blueprint Trigger for a state change & use the !input directly.
E.g.
blueprint:
domain: automation
input:
input_select_one:
description: something
selector:
entity:
domain: input_select
input_select_two:
selector:
entity:
- platform: state
entity_id:
- !input input_select_one
- !input input_select_two
- service: notify.persistent_notification
message: "{{ trigger.id }}"
But if you want to make the !input optional, you need to write the trigger as A template, but how do you do this? As an automation it can be done
description: test
mode: single
value_template: >-
{{ as_timestamp(now()) - as_timestamp(
states.input_select.input_select_one.last_changed ) < 1 }}
value_template: >-
states.input_select.input_select_two.last_changed ) < 1 }}
condition: []
But you can’t use A variable to do that for a Blueprint, or at-least I haven’t figured out how?
E.g.
blueprint:
domain: automation
input:
input_select_one:
selector:
entity:
input_select_two:
selector:
entity:
trigger_variables:
input_select_one: !input input_select_one
input_select_two: !input input_select_two
value_template: "{{ as_timestamp(now()) - as_timestamp( states.[input_select_one].last_changed ) < 1 }}"
value_template: "{{ as_timestamp(now()) - as_timestamp( states.[input_select_two].last_changed ) < 1 }}"
Any tip’s would be much appreciated?
