How does a no-neutral switch get power?
I know how to install and set up a “no neutral switch”. What I’m asking here is how these switches work internally. They need power to run the LED and zigbee radio and they have to work if the switch relay is open or closed for a long time.
So if I were to smash one of these switches and look at the circuit board, trace the connections, what would I find?
My guess is that this switch is never really closed but only in a very high impedance state so that some current always flows and then maybe there is a transformer to “steal” a few microamps.
We can speculate about how it COULD work, but does anyone really know? I’d like to find a schematic.
correct. a small amount of power runs through
It treats the load as a resistor back to the line source, and pulls a small amount thru. Hopefully not enough to make the light shine. When the bulb load and the switch aren’t good enough matches, you add a bypass cap or resistor to leak a little more around the bulb.
Just like the good old X-10 switch days!
That is what I figured. This much is easy/obvious
But the question is the details. How to effecently convert to leakage current when the bulb is off and the full current when on to the required 3.3 volts DC. I can think of a few complex and expensive ways but the entire switch sells for $13. So there must be an inexpensive trick.
This is where engineers earn their money. Anyone can find expensive ineffcent solutions, minimim cost reliable solutions are harder.
It’s what Troon said. As you’ve observed, it’s not trivial to do efficiently though.
Perhaps this will satisfy your curiosity.
Note that the smart switch itself still requires a neutral. It’s just that you don’t need a neutral return from the load.
Think of it this way: normally there will be two circuits involved, especially with smart switches with a dry contact relay. One circuit with a live and neutral powers the switch, while the load has its own live and neutral and goes via the relay. If you remove the neutral at the load, you still need to complete the circuit, so you need to get to the smart switch’s neutral instead. That’s why the smart switch will now be inline and won’t have a dry contact relay. Now you should see why there will be this always-on stray power through the load: it’s needed to keep the smart switch powered.
Yes, we all know WHAT these swiches do. The question is HOW,
Even the linked artical does nt answer: It says (quote) The Difficulty To Create No-Neutral Switches. The true difficulty of creating a no-neutral switch is in minimizing that wattage required in its OFF mode. This is a problem facing manufacturers, who have been trying to perfect this technology for years. (end quote)
No much of an answer, they only say it is a hard problem.
I guess that I will have to sacrefice a switch and smash the plastic case and look inside.
Look at the diagrams in the article and my explanation. It tells you how it’s wired. There’s no other trickery. It’s high school circuitry – that’s how it’s wired. The extra tricks needed isn’t to get this working in principle: It’s to improve power consumption, or flicker, or a dimly lit light – and those things will depend on the specific device. Open one up if it fancies you.
Sir Goodenough already pointed out there could be a bypass (Shelly does it this way), like a cap or resistor, to let more of the current flow through there instead of the light. That’s one way, but it’s not necessary to get it working in principle. The trade-off is between having the lowest possible power to keep the smart switch’s electronics on without turning the light on.
What you’re quoting is an optimisation problem – not the principle to get it working.
I have this exact issue. I have a single Aqara no-neutral wall switch and a single hue bulb. The Aqara switch only works when the hue bulb is on, even when the Aqara is in decoupled mode.
If I turn the hue bulb off (via the bulb not switch) the wall aquara flickers and eventually turns off. This cuts power to the hue bulb and means I am no longer able to use the bulb or the switch.
What resistor or capacitor should I be using to allow enough current to pass to keep the switch on?
Hello John,
Similar to this but must be installed at the load bulb to work, not at the switch because you have no neutral there.
https://www.amazon.com/PCS-Load-Resistor-Lighting-ILR-10K/dp/B01ES0AYU8
https://www.amazon.com/PCS-LDS-120V-Dimming-Stabilizer-120V/dp/B07B1LY2J9
I recently found this video from Big Clive that explains how a no-neutral motion sensor works including a walk though of the circuit.
While it is not a smart device, the power circuit in it is probably a similar.
Adding a weird setup from mine:
I have a socket box with three sockets, but I decided to replace one socket with a smart switch to control anything else via HA.
I used a non-neutral switch (touch panel).
So, there is no actual load for this switch, because it’s a socket wire and it comes nowhere, but it has a neutral.
I decided to add a “fake” load using a capacitor from another Zigbee device (Zb relay), and added it from the L1 to the sockets N wire.
And it seems like working, lights are on, the first relay is clicking one or two times, but then the switch turns off completely, and to get it to work, I need to break the circuit and connect it again.
As I understand, the capacitor might not draw enough current, or the system equalises itself as soon as the capacitor is loaded.
Is there a better workaround to get this switch working without an actual load?
Or is this a dead-end, and I should just use a neutral-required switch in such a setup, to make it work as a virtual switch?
Use a device made for that purpose (load) like the ones I linked above, not some random device.
Also I would think if you put a device as an actual load there, so when it turns on it stays on, that would help.
This is something I’ve considered, but the problem is to keep it always ON.
You can always accidentally power it off by touching the switch.
Another approach is connecting the switch in parallel, but it probably should not work.
Here is a really helpful video (from 2019!) that explains this concept quite well: https://www.youtube.com/watch?v=VNYcD7MEp4A
Perhaps you could get it to work with a circuit like the one shown in this video: https://www.youtube.com/watch?v=YItMu6VJGBI
Alternative Paradigm: Kinetic Energy Harvesting
Since power stealing always introduces trade-offs (flickering, minimum load requirements, capacitor installs), another clean hardware approach is Kinetic Energy Harvesting:
Instead of trying to power a wireless transmitter continuously from the wall’s AC line via parasitic current, the wall switch requires NO power at all when idle.
When physically pressed, a micro-kinetic generator harvesting module inside the switch converts mechanical energy into enough micro-joules of electricity to power an ultra-low-power RF transmitter to send an instant impulse signal. The actual switching/relay control is placed at the light fixture (where Line and Neutral are naturally available).
This bypasses the parasitic power stealing dilemma entirely—no minimum load needed, no LED ghosting, zero batteries, and zero standby current.
I’ve been using and testing various kinetic self-powered switch setups with HA receivers—it’s been a super reliable zero-battery solution for no-neutral retrofits!
If you’re going to do that, you might as well just use a smart neutral-required module, of which there are loads (pun intended) to choose from.
Out of topic, but these kinetic switches concretely show how far we are from really low power approach with common esphome devices for example. Kinetic switch asks few nAh to send simple wireless data packet. Esp32 would consume millions times more. It’s capable of streaming video and not designed to send low power on/off commands occasionally.
If you sell kinetic devices like @Lemon_HomeTech it’s very much on-topic in terms of advertisment. Just drop some off-topic AI slop im a dead thread and the ha community is happy to take it :smile:
