I just setup the Letsencrypt add-on in HACS. After I start it, it gets the cert and stops. How does it know when to renew the cert before it expires? Or do I have to set up this renewal myself?
No, you didn’t. There’s no add-ons in HACS.
Well, I navigate to it from HACS
, Add-ons
, Go now
Add-ons are located under Settings, indeed you can get there in 2 clicks instead of doing 3 going the wrong way through HACS…
Anyhow, every time the Let’s Encrypt add-on starts it checks the certs and renews if required. This is usually fine if like me you restart your HA often enough, but otherwise search the forums and you will see examples of automations to renew the certs on a regular basic.
That link is there for all the people that don’t understand what HACS is, and what it does. It was easier for the HACS dev to do that than try to explain to a constant stream of people that HACS doesn’t have add-ons.
Actually it is still quite confusing with the plethora of terms: add-ons, integrations, frontend, services. To a layman like me, they all do the same thing: extend home assistant to provide more features.
There is a glossary.
alias: "@Let's encrypt certificate check"
description: Will expire in 3 weeks
- platform: time
at: "04:00:00"
condition:
- condition: template
value_template: >-
{{ (states('sensor.cert_expiry_timestamp_ha_certificate_my') | as_datetime or
now()) - timedelta(days=21) < now()}}
- service: notify.mobile_app_ip12
title: Let's Encrypt
message: >-
Your Certificate will expire in 3 weeks, trying to renew, please
verify
- service: hassio.addon_start
addon: core_letsencrypt
mode: single
Thanks, the condition is helpful, otherwise my HA needs to restart daily
Note that a certificate renewal does require a restart eventually, as the core needs to reload the certificate (which it only does during a startup).
But, since the certificate is renewed 3 weeks before it expires, it is likely you will restart at some stage during that time
value_template: >-
this seems to always return true for me. Any idea why? Thank you.
Use the name of your own sensor.cert_exipiry_timestamp_ha_
Got it. Thanks. I had to add an INTEGRATION under SETTINGS first (Not HACS):
Certificate Expiry
, give it the domain to testNotifications
and press e
on the keyboardsensor.cert_expiry
to find the exact key to useGOODNESS… I just realized that HACS
has Integrations, which is completely different from Integrations under Devices & Services
… no wonder people are confused.
