How does the date type work?
I’m trying to add a “last calibrated” date to my ESPHome device, which ideally is populated from the ESPHome side (a hardcoded date that I change when I calibrate the device) and readonly in Home Assistant.
Yes, I could make a text sensor, but where’s the fun in that. (And I was hoping that when it’s a proper date I can build some automations around it.)
It is important that I have a way to say “never”.
I added this to my ESPHome YAML:
datetime:
    type: date
    name: Last calibration
    optimistic: true
But no entity appeared in Home Assistant. Maybe because it has no value yet? How do I set one, preferably one that shows up as “unknown” or “never” or something like that?
Your yaml works fine - have you added the device to HA in the ESPHome integration?
I use MQTT and all the other entities of the device are discovered, but not the date template one.
Maybe a discovery issue? Try logging an issue on GitHub. They’ll let you know quick enough if it’s not a bug. :smile:
EDIT: do you need to remove then add the device for MQTT discovery to run again? I generally use the API so I’m unsure…
It says on MQTT - Home Assistant
<component>: One of the supported MQTT integrations, e.g., binary_sensor […]
There is no MQTT Date component, so that’s likely it.
