How get access for package published into ghcr.io
I use builder for create package in ghcr.io
But when I try install addon from HomeAsstant I get error:
Can’t install ghcr.io/maxifly/yabackup-aarch64:2.0.2-b: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2.0.2-b&fromImage=ghcr.io%2Fmaxifly%2Fyabackup-aarch64&platform=linux%2Farm64: Internal Server Error (“Head “https://ghcr.io/v2/maxifly/yabackup-aarch64/manifests/2.0.2-b”: denied”)
Package and repository is public.
I cant understand where my wrong
My Actions code:
name: Create and publish a Docker image to GitHub
on:
  workflow_dispatch:
env:
  GIT_TAG_NAME: dev
jobs:
  build-and-push-image:
    runs-on: ubuntu-latest
    permissions:
      contents: read
      packages: write
    steps:
      - uses: actions/checkout@v4
      - uses: docker/[email protected]
        with:
          registry: ghcr.io
          username: maxifly
          password: ${{ secrets.GITHUB_TOKEN }}
      - uses: home-assistant/builder@master
        with:
          args: |
            --all \
            --target ./yabackup \
            --docker-hub ghcr.io/maxifly/yabackupaddon \
            --addon \
            --no-cache
Sorry, is my mistake
I write incorrect path into “image” field in addon config.yml file
