Hi
it’s possible to create a “hard” token to watch my media?
For example:
https://abc.duckdns.org:8123/media/local/double-take/matches/00498fec-37cc-4b46-841a-989219bb9863.jpg?authSig={long live token}
Hi
For example:
Using home assistant tokens you can only access folders below /config/www which in your url is available as /local/
If you would like to access your local media folder located as /media/local you will have to mount (symlink - never tested if this works?) it below /config/www (e.g. /config/www/mysub) so you can access it via e.g. /local/mysub.
My problem is when I doing automation with notifications
I want to get last image from “matches” folders
Where I used in the automation on my local address all working well only if I connet with my phone to Wifi
When my phone disconnected from wifi I got only alert without image
I really don’t know how to solve it
Based on your description I would say this seems not be a problem directly with home assistant, but with access to your server instance in general.
Can you manually browse the image from your phone when you are not within the wifi?
Is your HA instance exposed to the internet (either via Port Forwarding or via Home Assistant cloud) ?
No - I can browse from phone to image only when I’m connected to wifi
Yes - my HA was exposed to the internet via DuckDns and internal port forwarding, and its work great
so as said - your image is within a location which is not accessible from external.
Have you tried to save the image into /config/www/ folder as said and tried to access it via /local/myimage.jpg ?
Yes, I success.
https://xxx.duckdns.org:8123/local/test.jpeg
The problem like you mentioned it’s not secure. Anyone who knows the file name can watch it
Absolutely true.
I am not aware about a way HA is able to do that kind of authentication for you.
As I see it there would be only two options:
a) Security through obscurity …not very great but you could do a randomize jpg name and have it with this more unlikely fore someone to get it …and as you are doing notifications I would assume you do not need it forever, but can just delete it after e.g. 12 hours. A lot of services on the web do it this way.
b) You setup a separated webserver (e.g. apache), expose this to web, handle authentication there and just sent a link via the HA notification.
I have another option to use “api/hassio_ingress”
https://xxx.duckdns.org:8123/api/hassio_ingress/wxZONpw7YVgYS7hH32s_Bs-8nalnsaKXI77rr2QEou8/api/storage/matches/8f4f197b-8450-4a05-bbd8-12cbaf490d1e.jpg
When I’m trying access from incognito mode I got - 401: Unauthorized
This is wxZONpw7YVgYS7hH32s_Bs-8nalnsaKXI77rr2QEou8
not a token to access?
Any solution for this?
So I have found a pseudo solution to this. Navigate to your photo in your /media/path-to-photo/test.jpg
Get the url link of the picture that is presented and use that url for your purpose. The auth token at that endpoint will work for a while. A long lived token will not work in place of this token.
Researching how to refresh my endpoint with a fresh token programmatically with each notify service call brought me here.
I have used this before to get the access token for /api/, may give you an idea
- service: notify.notify_someone
message: Drive image
notification_icon: mdi:cctv
image: >-
/api/camera_proxy/camera.drive_person?token={{
state_attr('camera.drive_person','access_token') }}
This is great!! It took me a little bit to figure out how to incorporate this into a picture card but it worked!
@reef-actor much appreciated for the assist!
The configurations that worked for me.
In configuration.yaml
# Create camera entity from a file.
camera:
- platform: local_file
name: <choose_your_name>_unsecure # Insecure option
file_path: "/config/www/<path_to_file>"
name: <choose_your_name1> # Requires authentication
file_path: "/media/<path_to_file>"
In automation
service: notify.<device_to_notify>
message: Someone was seen at the door!
title: A person was detected!!
data: # API to access the camera entity created above
image: >-
api/camera_proxy/camera.<choose_your_name1>?token=state_attr('camera.<choose_your_name1>','access_token')
entity_id: camera.<choose_your_name1>
actions: # action buttons in notification
- action: URI
title: View Camera Feed
uri: /lovelace/<path_to_card>
- action: URI
title: View Snapshot
yaml for the picture card
show_state: true
show_name: true
camera_view: live
type: picture-entity
image: >-
/api/camera_proxy/camera.<choose_your_name1>?token={{state_attr('camera.<choose_your_name1>','access_token')
entity: camera.<choose_your_name1>
*edited for consistent naming
