Hello where i can find api of darksky? I dont find in hassio.
It seems currently it is not possible, as the underlying library does not support the Language parameter:
@namadori i find one solution for translate it for my language
i make it
estadodotempo:
friendly_name: âCeuâ
value_template: >
{%- if is_state(âsensor.dark_sky_summaryâ, âPartly Cloudyâ) -%}
CĂ©u Parcialmente Nublado
{%- elif is_state(âsensor.dark_sky_summaryâ, âClearâ) -%}
Limpo
{%- elif is_state(âsensor.dark_sky_summaryâ, ârainâ) -%}
Chuvoso
{%- endif -%}
Thatâs a great solution for the short state.
I was thinking about the long summary description, e.g. âLight rain throughout the week, with temperatures bottoming out at 48°F on Sunday.â This is too complex and variable to be translated with templates, can be requested in many languages via the Dark Sky api (https://darksky.net/dev/docs) , but it seems that the Lang parameter was not implemented in the python library.
@namadori the other solution is that DarkSky forecast language, other than english but i have running HA throught Hassio and not is possible edit Api. On hassbian is it possible because i tried it before and works fine.
To edit the libraries in Hassio you can try to follow the instructions in this post: Modify external pip libraries
Still havenât tried, but it should work. I donât know if the changes will survive across updates.
It also seems that the changes to the original library has already been implemented, but the owner did not merged the PR.
