Hello
How I get the device ecowitt weather sensor data upload to Home assistant green gateway complete API string and the Home assistant IP ,and I dont know use HTTP or MQTT and the data format please give me example ?
Thank you for your assistant
Hello
Have you followed the instructions on the Ecowitt integration page?
Thank you for your reply,but I need the ecowitt weather sensor device upload data to Home assistant green gateway url api example same as http get upload api to weather underground (WU)https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=abcdef&PASSWORD=12345678&dateutc=now&winddir=270&windspeedmph=10&dewptf=0&tempf=28.5&humidity=44&weather=&clouds=&UV=2&rainin=0.3&baromin=29
Not sure what you are trying to achieve.
The configuration for Weather Underground and the connection for Home Assistant done under “Customised” in the Ecowitt app on your phone are completely seperate.
The operate independently from each other, data can be sent both to WU and HA.
Not sure what this is…
