How I get The Ecowitt 2000A or any Ecowitt model Home assistant integration source code to develop control and display ecowitt weather sensor ?
Thank you forr assistant
How I get The Ecowitt weather station gw2000A or any Ecowitt weather station ulpoad data to Home assistant URL
Sorry, I can’t teach you how to develop new capabilities for an integration.
This is a good place to start learning:
Thank you for your help
Too information on document I cannot looking for weather station integration upload data to Home assistant local gateway URL ,Could you tell me URL and is HTTP POST and is Json data format ?
I do not understand your question.
I dont know the Ecowitt station integration upload data to Home assistant protocol is using HTTP POST or MQTT ?
Isn’t that why you wanted a link to the source so you could see how it was done?
I still cannot looking for the Ecowitt station integration send data to Home assistant protocol is using HTTP POST or MQTT ? and I try wireshark to test between the ecowitt Gw2000A and Home assistant communication no show MQTT 1883.
