So, I recently ran out of space on my Ubuntu server and found that home-assistant_v2.db was the culprit, eating up a massive 95 GB. I had set my Home Assistant recorder to keep state data for 70 days (purge_keep_days), which should be manageable — but 95 GB? Way too big.
Step 1: Database Analysis
I started with some database analysis using the sqlite3_analyzer tool: sqlite3_analyzer home-assistant_v2.db. It took a few minutes to complete due to the database size, and generated a large output but the most interesting was this:
/** Disk-Space Utilization Report For home-assistant_v2.db
Size of the file in bytes......................... 98372806656
Bytes of user payload stored...................... 51006611082 51.9%
*** Page counts for all tables with their indices *****************************
STATE_ATTRIBUTES.................................. 79849678 83.1%
STATES............................................ 15744915 16.4%
*** All tables and indices ****************************************************
Unused bytes on all pages......................... 34480337591 35.1%
*** Table STATE_ATTRIBUTES and all its indices ********************************
Percentage of total database...................... 83.1%
Number of entries................................. 173759998
Bytes of storage consumed......................... 81766070272
Unused bytes on index pages....................... 106686636 11.6%
Unused bytes on primary pages..................... 34106211104 42.2%
Unused bytes on overflow pages.................... 59110 1.5%
Unused bytes on all pages......................... 34212956850 41.8%
Turns out, 83% of the space was taken up by the STATE_ATTRIBUTES table, and over 40% of page bytes are unused! I tried using VACUUM to free up space, but it had no effect. This suggests that the STATE_ATTRIBUTES table just stores data inefficiently. Maybe a future HA update will address this.
Step 2: Identify Data Bloat Sources
To dig deeper, I checked HA Docs on data storage and realized that the real issue might be in the STATES table. STATE_ATTRIBUTES likely bloats because of some entities generating an extreme amount of state changes. I connected to database using sqlite3 home-assistant_v2.db and used this query to find the top 100 entities with the most state changes:
SELECT
states_meta.entity_id,
COUNT(*) AS record_count
FROM
states
LEFT JOIN states_meta ON (states.metadata_id = states_meta.metadata_id)
GROUP BY states_meta.entity_id
ORDER BY record_count DESC
LIMIT 100;
The result showed that most bloated records were from power meters and device trackers:
entity_id record_count
number.smart_meter_update_frequency 5222612
sensor.smart_meter_power_b 5222610
sensor.smart_meter_power_a 5222610
sensor.smart_meter_energy_produced_b 5222610
sensor.smart_meter_energy_flow_b 5222610
sensor.smart_meter_energy_b 5222610
sensor.smart_meter_energy_a 5222610
sensor.smart_meter_current_b 5222610
sensor.smart_meter_current_a 5222610
sensor.smart_meter_power_factor_b 5222609
sensor.smart_meter_power_factor_a 5222609
sensor.smart_meter_power_ab 5222609
sensor.smart_meter_energy_produced_a 5222609
sensor.smart_meter_energy_flow_a 5222609
switch.relay_entrance 900775
sensor.relay_entrance_energy 900774
sensor.relay_entrance_voltage 900773
sensor.relay_entrance_power 900773
sensor.relay_entrance_linkquality 900773
sensor.relay_entrance_current 900773
device_tracker.ae_34_12_cd_78_45 596372
device_tracker.91_b8_23_ac_09_ef 595466
device_tracker.4f_76_01_aa_92_cd 594797
device_tracker.bc_3d_10_e4_17_a9 560428
device_tracker.33_e7_54_b1_8c_60 548377
device_tracker.1d_c9_02_da_9e_fb 513255
device_tracker.9e_54_48_20_f3_ea 487929
device_tracker.72_a8_3d_11_6c_0f 452719
media_player.tv 350620
switch.aqara_power 164512
switch.aqara_power_power_outage_memory 164508
sensor.aqara_power_power 164506
sensor.aqara_power_energy 164506
sensor.aqara_power_device_temperature 164506
If you want to get the output in the same format, you need to execute .mode column and .headers on before the query. Execution of the query took a long time too. Be prepared if you have a huge DB. There is a DbStats addon which will do the same and show you nice charts.
I decided that while I want to keep 70 days of state data generally, these specific entities only need a few days of history.
Step 3: Automate the Purge
Luckily, Recorder docs provided examples for exactly this: purging high-frequency data, like power meters. I set up two automations:
alias: Purge noisy device_tracker entities
description: Reduce DB size by purging state changes for specific trackers
triggers:
- trigger: time
at: "05:00:00"
conditions: []
actions:
- action: recorder.purge_entities
metadata: {}
keep_days: 1
entity_globs:
- device_tracker.??_??_*
mode: single
and
alias: Purge noisy power sensors
description: Reduce DB size by purging state changes for power sensors
triggers:
- trigger: time
at: "04:00:00"
conditions: []
actions:
metadata: {}
keep_days: 5
entity_globs:
- "*.smart_meter_*"
- "*.relay_entrance*"
mode: single
I also used the File Size integration to monitor the DB size, which is perfect for tracking storage impact.
Step 4: Final Cleanup
The first purge run took a day since it seems to delete records one by one. After purging, I checked the DB size — and it hadn’t shrunk. In SQLite, deleted data doesn’t usually free up space automatically, so I needed to run VACUUM to reclaim it. Recorder also calls VACUUM every second sunday (if you didn’t unset `auto_repack`) or when you call `recorder.purge` action with `repack` attribute.
Since VACUUM creates a temp file for a shrinked database (which I didn’t have space for), I connected an external drive, stopped HA and ran VACUUM INTO [external drive path] in the sqlite3 CLI. This reduced my DB to 12 GB! After replacing the original DB with the vacuumed one, I also deleted home-assistant_v2.db-wal and home-assistant_v2.db-shm files (that’s important!). Started Home Assistant, and everything worked perfectly!
Results
With this cleanup, I reduced the DB size by 85%, and I’m still tracking 70 days of data for most entities. If you’re struggling with a bloated home-assistant_v2.db, I hope these steps help!
