mine stopped then started working again but with wrong distances, I kinda really need this to be working for my drip irrigation system… it was working perfectly just 1 week ago, but since then all is wrong,
my code didn’t change though could anyone be kind enough to help me out ?
here’s the code:
- platform: ultrasonic
trigger_pin: GPIO 4
echo_pin: GPIO 5
name: 'Water tank Level'
unit_of_measurement: '%'
accuracy_decimals: 1
update_interval: 1s
icon: mdi:water-percent
filters:
- lambda: return ((((x*100)-8)-(46-8))/(46-8))*-100;
- sliding_window_moving_average:
window_size: 10 #creates a moving average of the last 10 values
send_every: 1 #sends the moving average at every measurement (but only if it passes the delta filter below))
send_first_at: 1 #after startup immediately start sending the result rather than wait for the first 10 measurements
- delta : 0.05 #only send the result if the level difference with the last sent result is higher than this
- filter_out: nan
trigger_pin: GPIO 4
echo_pin: GPIO 5
update_interval: 2s
name: 'Water Tank Volume'
unit_of_measurement: 'l'
icon: mdi:cup-water
accuracy_decimals: 2
filters:
- lambda: return ((((x*100)-8)-(46-8))/(46-8))*-70;
- filter_out: nan
It seems that you are running two sensors on the same gpio pins. This is probably going to cause strange behavior. I guess that you only have one sensor and then calculate the volume and the percentage of the tank.
The easiest solution is to have the distance as one sensors.
Then make two template sensors with lambda.
trigger_pin: GPIO 4
echo_pin: GPIO 5
unit_of_measurement: 'm'
update_interval: 1s
filters:
- filter_out: nan
update_interval: 1s
lambda: |-
return ((((id(dist).state*100)-8)-(46-8))/(46-8))*-100;
icon: mdi:cup-water
lambda: |-
return ((((id(dist).state*100)-8)-(46-8))/(46-8))*-70;
So the template values are referring to distance forme the distance sensor.
Then I refer the value by id(dist).state in the template
I’m not sure that I got everything right. But maybe this gives something to try.
wait what?
can you please use my info from the code and give me an explanation using my infos, i really am not so well versed in esphome yet. or HA for that matter!
lol
You have told esphome that you have 2 sensors connected to the same pins.
According to you that worked for avail at least. It was little bit surprising. That means that esphome is measuring distance on the same sensors from two different parts of the “system”. There is no guarantee that these will not interfere with each other and give strange values back. Its very hard to know whats going to happen.
So the theory is that it causes your problem. Sometimes it works and sometimes it doesn’t.
So my example above trying to solve this.
I have defined 1 sensor because you have one sensor. It measures the distance.
Then I defined two template sensors that take that raw distance value and send them up as the percentage and the volume.
One other way to try if these interfere with each other is do comment one of the senors away in the code and see if you get the correct measurement.
It can also hardware issues or moisture condensation on the ultrasonic sensor or something.
Does it say anything in the logs.
thanks for the reply, I obviously tried to use them individually to the same sudden bad results.
I wouldnt know how to implement your example, im quite new to all this language, i am learning but there’s a steep learning curve for a non-coding person. i’m getting so much better thanks to people like you who are willing to help.
But I see that the filter_out: nan is almost at the bottom.
Try to move it upto the top placement in the filter part.
filters:
- filter_out: nan
I dont know what going to happen when you do other filters or calculations on nan.
The sliding window maybe update the counter that it got a value but its a bad one that should not update the value. Could be an issue.
ok, but what i dont understand is why it was reporting near perfect results for a few weeks then suddenly stop? no change on my part… appart from HASSIO update.
now its reporting with your code in and only that one
-172 l tank volume
-247% full
small test tank is 56L x35 W x45 H sensor is at 8 cm from water when completely full.
there is definitely something wrong
heres an exerpt of the log:
[19:04:36][I][app:105]: ESPHome version 1.17.2 compiled on May 12 2021, 19:03:57
[19:04:36][C][wifi:443]: WiFi:
[19:04:36][C][wifi:303]: SSID: [redacted]
[19:04:36][C][wifi:304]: IP Address: 192.168.1.142
[19:04:36][C][wifi:306]: BSSID: [redacted]
[19:04:36][C][wifi:307]: Hostname: 'ultrasonic_v2'
[19:04:36][C][wifi:311]: Signal strength: -61 dB ▂▄▆█
[19:04:36][C][wifi:315]: Channel: 6
[19:04:36][C][wifi:316]: Subnet: 255.255.255.0
[19:04:36][C][wifi:317]: Gateway: 192.168.1.1
[19:04:36][C][wifi:318]: DNS1: (IP unset)
[19:04:36][C][wifi:319]: DNS2: (IP unset)
[19:04:36][C][logger:185]: Logger:
[19:04:36][C][logger:186]: Level: DEBUG
[19:04:36][C][logger:187]: Log Baud Rate: 115200
[19:04:36][C][logger:188]: Hardware UART: UART0
[19:04:36][C][ultrasonic.sensor:035]: Ultrasonic Sensor 'Filter Tank VolumEsti'
[19:04:36][C][ultrasonic.sensor:035]: Unit of Measurement: 'l'
[19:04:36][C][ultrasonic.sensor:035]: Accuracy Decimals: 0
[19:04:36][C][ultrasonic.sensor:035]: Icon: 'mdi:water'
[19:04:36][C][ultrasonic.sensor:036]: Echo Pin: GPIO4 (Mode: INPUT)
[19:04:36][C][ultrasonic.sensor:037]: Trigger Pin: GPIO5 (Mode: OUTPUT)
[19:04:36][C][ultrasonic.sensor:038]: Pulse time: 10 µs
[19:04:36][C][ultrasonic.sensor:039]: Timeout: 116618 µs
[19:04:36][C][ultrasonic.sensor:040]: Update Interval: 5.0s
[19:04:36][C][captive_portal:169]: Captive Portal:
[19:04:36][C][ota:029]: Over-The-Air Updates:
[19:04:36][C][ota:030]: Address: 192.168.1.142:8266
[19:04:36][C][ota:032]: Using Password.
[19:04:36][C][api:095]: API Server:
[19:04:36][C][api:096]: Address: 192.168.1.142:6053
[19:04:36][C][wifi_signal.sensor:009]: WiFi Signal 'WiFi Signal Sensor'
[19:04:36][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[19:04:36][C][wifi_signal.sensor:009]: Unit of Measurement: 'dB'
[19:04:36][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[19:04:40][D][api.connection:617]: Client 'Home Assistant 2021.5.2 (192.168.1.144)' connected successfully!
[19:04:41][D][ultrasonic.sensor:026]: 'Filter Tank VolumEsti' - Distance measurement timed out!
[19:04:46][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 2.65 m
[19:04:46][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 30.21954 l with 0 decimals of accuracy
[19:04:51][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 6.54 m
[19:04:51][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 56.86234 l with 0 decimals of accuracy
[19:04:56][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 8.90 m
[19:04:56][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 76.56226 l with 0 decimals of accuracy
[19:05:01][D][ultrasonic.sensor:026]: 'Filter Tank VolumEsti' - Distance measurement timed out!
[19:05:06][D][ultrasonic.sensor:026]: 'Filter Tank VolumEsti' - Distance measurement timed out!
[19:05:11][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 1.65 m
[19:05:11][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 61.52770 l with 0 decimals of accuracy
[19:05:16][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 8.30 m
[19:05:16][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 70.77032 l with 0 decimals of accuracy
[19:05:18][D][sensor:099]: 'WiFi Signal Sensor': Sending state -61.00000 dB with 0 decimals of accuracy
[19:05:21][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 6.93 m
[19:05:21][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 73.80261 l with 0 decimals of accuracy
[19:05:26][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 10.34 m
[19:05:26][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 82.64629 l with 0 decimals of accuracy
[19:05:31][D][ultrasonic.sensor:030]: 'Filter Tank VolumEsti' - Got distance: 11.50 m
[19:05:31][D][sensor:099]: 'Filter Tank VolumEsti': Sending state 91.26496 l with 0 decimals of accuracy
actual disrtance from top of water to sensor: 22-23cm
total capacity of reservoir 70l
empty res distance: 46cm
dist. to top of water from sensor when completely full: 8cm
no condensation happening, sensor is clean… this is really weird.
used to be working perfectly, it just stopped being really accurate and started to do this , just like that…
heres the conf im using right now with @birchman suggestions and some “timeout + update interval” modifications added!
The timeout is supposed to be some kind of delay in time I thought? Am I wrong?yes the bottom of the tank is 46cm (rubbermaid bin)
ill look for issues with the cables but i doubt that is the issue since the sensor+nodeMCU box is really close from the reservoir like less than 20cm…
I received a pressure transducer, Ill also try that.
if you or anyone have any suggestion for me I’m really open!
I’m really frustrated about this thing. I’ve already setup my secondary method using aquarium float switches, they work perfectly, but I wanted 1 main method and a backup because i do not want to flood my neighbours balcony!
The timeout is the maximum time that the sensor should wait on an echo to come back expressed in a distance (So the user doesnt need to calculate the number microseconds it takes for sound to travel the distance to the maximum distence back and forth.
In your case you have configure it to be able listen to echos that have travel 20 meters. Which is more than the senor can detect.
Because you are only interested to measure distances between 0-0.46m then you should lower that value to “1m” . I dont know how much it helps its all depending on the implementation.
Thats the only thing i can see from the configuration.
I suggested to check the cables or the sensor because we have soon checked all configuration.
Then its only cabeling or faulty hardware or bugs that we dont know about. But it easier to just to poke on the cabelng and see whats going to happen.
The pressure transducer I have not tried my self. I guess a analog out. The ADC in the esp8266 and esp32 is rather bad. So you need to filter it quite hard or use a ads1115 external adc.
