I have about 53 mifloras that I want to connect to hassio. I generated the config and under sensor section in the configuration.yaml i had them listed like this:
- platform: miflora
mac: 'C4:7C:8D:63:C8:69'
force_update: true
median: 4
monitored_conditions:
- temperature
- battery
- moisture
- conductivity
- light
and so on till FL53
I’ve tried with different properties like tweaking the median, scan_interval but no luck. I was able to get the readings of alot of them when i set the median to 3 still had a couple of the unavailable and some of them had partial values.
I though it was a Bluetooth range issue. so i tried scanning them through a raspian (another raspberry pi 3b that I have) they are placed side by side. and I’m able to scan all of them, so range is not an issue.
I have verified all of them, the mac addresses are correct. I have tested the same list via a python script (using the miflora library) on the other Pi
I think it has something to do with the configuration that I can’t get my head around or maybe I’m making silly mistakes. any ideas?
Home Assistant Version:
