By default, I see a progression bar in the speed test. However, I could not find in the documentation how often the service is really running or do I need an automation for this?
According to the docs it runs every hour.
But you can disable polling and then run it however often you want by using an automation.
Not very user friendly since you used to just set the run interval from right within the integration but it’s what we are stuck with now.
Thanks for the quick answer. Every hour works for me.
Where did you find this Information in the documentation?
Oh man, how could I have missed that. RTFM! Thank you for your help.
My post was a little pointless, sorry for that
I tried all these steps to run it from an automation but doesn’t seem to work. Its seems the update action in the automation runs but doesn’t actually do anything at all.
This thread is two years old - you’ll get more help if you start a new one. ![]()
