How operate two sensors using different gpio pins on esp8266 using esphome
I have two esp8266s running on esphome measuring soil humidity and air temperature I would like to use one esp8266 with both sensors on the same esp8266 but I don’t know how to write a YAML file to do this. Any help would be appreciated
Depends what the sensors are as to how they are configured. Post the working YAML config for both devices, properly formatted as code so it looks like this:
esphome:
  platform: ESP8266
  board: d1_mini
This is a useful resource for pin selection:
esphome:
 friendly_name: test03
esp8266:
 board: nodemcu
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "8MV+4ktgsJKcAWp5FmZYKNGoorVgxHGSPTXg0egbN7E="
ota:
 - platform: esphome
   password: "738748e54c103a5827829cf4d7e6c1e5"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Test03 Fallback Hotspot"
    password: "U6cS0fsm3i47"
captive_portal:
  platform: dht
  pin: GPIO4
  temperature:
    name: "Living Room Temperature"
    accuracy_decimals: 2
  humidity:
    name: "Room Humidity"
  update_interval: 60s
esphome:
friendly_name: test
platform: ESP8266
board: nodemcu
Enable logging
logger:
api:
encryption:
key: “/PIXC5GXrfpntz25avChMS/O0ZZ0Wx+KQmjyp1zTKSk=”
ota:
  • platform: esphome
    password: “aaa9f3e9a9f16beaca5b76a4a8a9a118”
wifi:
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Test1 Fallback Hotspot”
password: “PKiwoKBHiFia”
captive_portal:
platform: adc
name: “Soil Moisture Voltage”
pin: A0
filters:
  • sliding_window_moving_average:
    window_size: 15
    send_every: 15
Just copy one sensor to another boards yaml
esphome:
esp8266:
 board: nodemcu
# Enable logging
logger:
api:
  encryption:
ota:
 - platform: esphome
wifi:
  ap:
captive_portal:
  platform: dht
  pin: GPIO4
  temperature:
  humidity:
  platform: adc
  name: "Soil Moisture Voltage"
  pin: A0
  filters:
    - sliding_window_moving_average:
         window_size: 15
         send_every: 15
Careful: because you didn’t format the second one properly, so-called “smart quotes” have made it in:
should be:
and I think you want to separate the sensors as a YAML list:
  - platform: dht
    pin: GPIO4
    temperature:
    humidity:
  - platform: adc
    pin: A0
    filters:
           window_size: 15
           send_every: 15
Good eyes! :+1:
Thanks guys. i have been busy with other projects and eating and sleeping. Afte fighting YA<L files and following your guidance i have gert an installation.
Can you suggest a YAML editor and a tutorial on yaml
I can’t suggest anything, the best editor for yaml I have used is the one inside Esphome dashboard.
