How play a loop of siren sound with a buzzer
Hello everyone, I am an EspHome newbie.
I have created a project that uses an MQ-2 sensor and three LEDS, a green one that power on when the gas values are normal, a yellow one that lights up when the gas values are in an alert range and a red one when the gas values are dangerous.
In the latter case, the project also includes a buzzer sound.
I have managed to program the automations in esphome to do all this, the only thing I cannot do is the continuous buzzer sound.
At the moment it sounds for a few seconds and then stops, I would like it to sound for as long as the red led is on.
Another problem is that the volume of buzz is low, how I can up it?
Can you help me with this.
I paste the code I have created:
esphome:
  platform: esp8266
  board: d1_mini_pro
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "084ee2a40de4502d812f603bf7d39c18"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.131
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
    dns2: 8.8.8.8
  ap:
    ssid: "Esp-Tutorial Fallback Hotspot"
    password: "op5zTE1POuUc"
captive_portal:
output:
  - platform: gpio
    pin: D3
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D1
  - platform: esp8266_pwm
    pin: D5
rtttl:
  output: passive_buzzer
light:
  - platform: binary
    output: "green_LED"
  - platform: binary
    output: "red_LED"
  - platform: binary
    output: "yellow_LED"
  - platform: adc
    pin: A0
    update_interval: 1s
    filters:
      - multiply: 100
    unit_of_measurement: "%"
    icon: "mdi:percent"
    on_value_range:
        - above: 40
          then:
            - light.turn_on: red
            - light.turn_off: green
            - light.turn_off: yellow
            - rtttl.play: 'long:d=1,o=5,b=100:e6'
        - above: 30
          below: 40
          then:
            - light.turn_on: yellow
            - light.turn_off: red
            - rtttl.stop
        - below: 30.0
          then:
            - light.turn_on: green
Thanks for help and ciao
