I have 8 gen1 Sonoff Basics, 3 S20’s & 3 TH16’s. running for about 2 years & (touch wood) for the most part no issues.
there was one issue with a Sonoff basic, it thought the relay had failed, trying to contolr it via HA didn’t make a difference & the same with the push button. so I bought another (ready to replace it) - in the process, I turned the device off the at the wall. Tunred it back on a day or so later & its worked fine ever since.
When I restart my WiFi, there is one in a hard to reach place that need a bit of help to find the WiFi signal. but the than that, they have been rock-solid for the past 24 months.
I have 5 r2 and 12 shelly 1. After a reboot 1 r2 stopped to be reacheble. I had to hard reset using phisical button to restore connection. Since then it instable. I tried reset 5 and upgrating to 6.7.1 but nothing happens.
Moreover starting from few days some other device become unreachable. Those are shellies and are quite difficult to reach so I don’t know what to do because previous mentioned action didn’t work. Any ideas?
Recently, I tracked down some Sonoff wifi problems to an USB-C hub that I purchased for use with a Mac that was nearby the wifi router. It seems that USB-C can cause interference in the 2.4GHz frequency. The problem went away after replacing the hub.
Since v7.1.2 there’s a “lite” build made specially for Sonoff Basics R1 and R2. These are known for poorer quality electronics (weak internal psu) which can cause instability with full-featured Tasmota builds which occasionally make CPU load spikes. Lite build was made especially for that - most modules left out, simple functionality left in.
Running lite on my Sonoff Basics for 2 months now, not a single reboot or hang.
