How restart a sattelite raspberry pi from within HASS
Dear HA users,
I have several RPi’s with sensors and pass their results on to the broker (my HASS) with mqtt. Sometimes a satellite RPi loses the connection with the server. At that point I would like to reboot into this ‘remotely’. From the command line I can do this with `'ssh -i /home/pi/.ssh/ppk ‘[email protected]’ sudo reboot"
Now my question is: can I also do this from HASS (possibly in Python with appdaemon)?
My HASS is running in Docker on an RPi4
Can someone help me on my way?
This should work:
You’ll probably need to place your ssh keys somewhere in your config directory to make them available inside the container.
Example of something similar: Wake on LAN - suspending Linux.
Thank you very mutch. That was the solution !
You marked your own post as the solution but it was @ondras12345 post that provided the real solution.
you should fix that.
