For some illogical reason I do not remember the password to access the frontpanel panel.
could I know how to reset it? for hassio?
Check out the docs. Specifically the lost owner portion linked below.
thanks! @allan
Did the same thing. I am trying to access the configuration folder to reset it but I cant manage access this?
I seem to be in a research loop with this. I need to reset all passwords, but to do so via SMB or SSH I need to know the passwords, which I thought were in my password manager but it seems not.
The guide to reset seems to assume you already know how to get in?
I am setting up a router so the device IP has changed which has kicked all my clients off and resulted in a complete mess. Even assigning back to the original static IP has kept my devices kicked off so only solution is to reset password it seems.
What device and OS are you on?
Thanks for replying, sorry if that came off as a big frustrated rant… because it sort of was.
Rpi 3 b+ hass.io
I ended up remembering the SMB password so got to delete the config. Which let me get back to onboarding, but that just does literally nothing, it just lets me hit the create account button but doesn’t progress
Delete the auth* files in < config >/.storage
So if the same thing happens to me, on my 0.100.3 hassio on RPi4, could I:
a) Restore a previous snapshot, if there was a simple password there? (I have another admin user, I just want to recover the “owner” password), copy those data for the offending user, restore the latest snapshot and edit the proper files with the offending user data?
b) Shutdown my Pi, and remove the microSD card, format another one, reinstall hassio from scratch, create password for initial user, save auth file entries for the offending user, shutdown, reinstall working SD card and restart, get into second admin account and edit config to add new/correct password data. Restart. Pray?
These may sound more onerous, but I don’t need to delete a lot of auth files with other stuff in them.
Any thoughts?
Thanks,
Ambi
OK. I just tried a) but with a twist:
Hass.io) and copy the whole tarball (zip file having multiple zip files inside) and place it on your local machine. Make sure you copy it and don’t “cut” it as it will remove it from HA.Cheers,
Ambi
I had this too, and removed the /auth files. when I reboot HA, it will come up with the onboarding screen for entering a new account. However, the button to create the account seems not to work. The browser console says
Object { error: “Response error: 500”, status_code: 500, body: “500 Internal Server Error\n\nServer got itself in trouble” }
Probably permissions should be set in a special way for /.storage?
